Im leaning towards the 5850 to replace the 8800 GTX. Ive had a google search. It appears my Gigabyte GA P35 DS3R (version 1) can support a 5850. Has anyone here made a similar upgrade with the same mobo? Feedback of any kind appreciated.
Graphic cards of PCI-E x16 2.0 would work fine even in PCI-E x16 1.0 slot. What you should check is to make sure is that you CPU is fast enough to keep up with the 5850. A Q6600 overclock to 3.7GHz/stock speed Phenom II X4 965/i5 750/i7 920 would roughly be the speed of CPU needed to not bottleneck the stock speed 5850 too much.Im leaning towards the 5850 to replace the 8800 GTX. Ive had a google search. It appears my Gigabyte GA P35 DS3R (version 1) can support a 5850. Has anyone here made a similar upgrade with the same mobo? Feedback of any kind appreciated.![]()
I think you misunderstood what I meant...I was merely suggesting to reduce the chances of bottlenecking, those are the level of CPU speed targeted.Let me get this right? A stock i7 920, bottlenecks a 5850?
Seriously?
