How do you choose which hard drive steam installs games onto?
18 Mar 2010
I dont want it to install games onto my C drive as it is an 80gb ssd.
the steam app itself is on my D drive - will steam automatically download games there?
i cant seem to find an option to specify the download location.
Steam should inherently install your games in the steam application folder. So if you install Steam on your D drive, the games will install on that drive too.
That's how I have mine setup; so irrespective of how many times I reinstall my OS, I don't have to repeatedly download all my games.
I'm guessing then there's no way you can have steam installed to partition C drive and have a few games on C but then install others on another partition of a hdd?
Reason being I obviously made partition C to small :p
though I guess I could try and make it bigger - would have to find a partition manager as the one on windows 7 won't work for that
Yep thats right.
I have Steam installed on my Games hard drive.
yes you can.
search on here for steam on multiple drives, it's fairly easy and doesn't need any other programs.
mlink command I think you use :o
yes you can.
The mlink command can be used to create a Symbolic link, which for example could be used to a allow a steam game to run from another location, basically after creating a symbolic link (supported in vista and win7) the OS will redirect the application to the location where you have copied the data to. I'm currently using a symbolic link I created to redirect steam to a game I copied onto my SSD.
http://www.maximumpc.com/article/howtos/howto_master_your_file_system_mklink
