Ok so going to try my hand at water cooling, but going to go s/h for now.
only doing a cpu loop for the moment till i can decide/afford what cards im going to get although most likely to be the gtx 275
So been offered these... Some may say the rad is to big but i want it to handle the gtx and maybe two later on
XSPC Dual Bay Reservoir Pump
http://www.xspc.biz/baypump750.php
D-Tek fuzion V2
http://www.dtekcustoms.com/d-tekfuzionv2cpublock.aspx
XSPC RS240
http://www.xspc.biz/rs240black.php
now here is were i am undecided,
do i go for Arctic Cooling Arctic F12 which is 57cfm, 25db on 100% or a Scythe Gentle Typhoon which is 50 cfm but 21db at 100%
also the artic has pwm plug were as the scythe has molex.
then other bits to complete
1/2" tubing, with anti-kink coils
fan controller only need a single one for rad fans as front and rear case fans will be controlled by mobo.
Non Conductive liquid.(PrimoChill or feser...maybe something else?)
any other things?
Also what are those fittings that have the screw type bit on them to securely fix the hose to the barb
D-Tek fuzion V2
XSPC RS240
any other things?
