Get the Venomous X over the Prolimatech. It will block one slot but that won't be a problem with 6GB ram.
The Prolimatech Megahalems does a very good job at cooling an i7 980X @ 4.2GHz so it's horses for courses.
You have a Biostar x58 don't you?
Not at all, I was gonna say that you're in for a treat!![]()
It is so much better at handling high memory clocks than the Biostar. I can never get 1600mhz properly stable on mine whereas the Rampage handles it fine at cas 8. The ram is a set of 1333mhz ocz platinums.
You could still use the 1st and second slot. Using my GTX260 to test, there wasn't a big performance impact when placed in the x8 slot. Just one or two FPS that wouldn't be noticeable when running two cards. Saying that, the only performance hit was in Far Cry 2 out of the games I tested.
hmm well if we rule out the ports ect...
i cant see the board being the issue i think your biostar has issues with your memory.
becuse i can run my memory 3x2 OCZ 2200 @1600 7.7.7.21 without any issues at all.
but hopefully this RE3 will let me run my cpu @4.2HT with my memory at 2200. default.
though im not even sure 2200 default will beat 1600 with tight timeings cause its with quadcore loose timeings benifited more but with i7 tighter seems to be faster lol
ohh what to do lol
