These style of games really are better with a controller, preferably an xbox 360 one, microsoft did great on that one!
Hmm for me, VC is showing as back on special for 1.49 again ? And SA at 3.49![]()
Not understanding why vice city works with xbox360 controler though SA doesn't. And why on vice city the resolution can go upto 1920*1080 while SA doesn't either. As wasn't vice city made before SA anyway?And mods! SA is a lot better on PC, a much more enjoyable experience.
Just tried GTA 1 steam version, wasn't confident it would work (Win7 64bit) on my system as I didn't get the free from rockstar ver to work. Spectacularly crashes my PC with 0x10E stop error. Awesome
Runs fine on XP VM mind![]()
I said VC works with controller, im saying SA doesn't.VC works with the 360 controller? When i had a quick try the right analogue stick wasnt working, only had a quick 2 min try on it tho just to check if the game was working, will have a proper try now that i know it works
Oh ok thats a shameWell the patch 1.01 ver has support for that res but version 3 (steam uses this) does not have any support for 16:9 resolutions. So you could run 1920x1200 (16:10) okay. It seems it uses a fixed resolution list where as VC and GTA3 generate resolution list from your pc.
http://www.widescreengaming.net/wiki/Grand_Theft_Auto:_San_Andreas
Only drove down the road on VC, umm it was B and X for left and right, the LT and RT button's didn't work and didn't detect in control settings and yer one of the analogue sticks didnt workI know. VC doesn't seem to work with mine (the right analogue doesn't work anyways, and a few buttons like triggers i think). It's the same with GTA3 and SA for me too, most things working other than right analogue stick and i think the trigger buttons.
Wish i still had my PS2 controller as that worked perfectly with them all iirc.
I'll have a fiddle round with it later if i can be bothered, if not i can just use M+KB for walking round and controller for driving.
So how is it not a good deal then?
