Caporegime
 - 18 Sep 2009
 - Dormanstown.
Disable C'n'Q lol.
lolDisable C'n'Q lol.
Guys, what are you using to monitor your temps??
On load Speedfan shows temps of 62 degrees on the CPU while core temps are 49.5. Should I be worried?
I thought core temps were meant to be higher than CPU temp or something!
Running at 3.6 ghz @ 1.40v
stanton4958, what do you get for CPU temp when you run HW monitor for example. Core temps for me is within 48-49 degrees
give us 20/30 mins and will do full load with prime 95Thanks! i know it may seem a big ask but can you try load for 10 mins and then take screenshot of hwmonitor?
try and put your cpu v down to 1.3250 v then your never go past 40/41cThanks you very much!
Now I'm pretty sure I have a funny CPU sensor. While core temps never pass 50 C at 1.4v, the TMPIN1 goes up to 62 degrees, in everest this is described as CPU temperature. I guess I have nothing to worry about?
just remberd that my tmpin1 hit 86c 1nc so dont wory about it mateJesus, Big Wayne is going to have a fit with all these quotes!
On a sensible note
I have a 1090T sitting here boxed I cant yet bring myself to opening it to try as I doubt ill see much of an improvement in what i use over my 555be @ x4?
Doing my first ever overclock at the moment and would appreciate some guidance.
I unlocked my 550 BE to 4 cores and it's running at 3.2Ghz at the moment as I upped the multi to x16 with fsb 200Mhz. Temps on idle around 30 and 47 max on load - are these okay?
The CPU voltage in CPU-Z is changing a lot between 1.280 and 1.3 (I havent changed any voltage settings) should it be doing that?
Does anyone have any suggestions on what clock speed I should be looking to reach and which temps to aim for?
Also, should I do anything with the RAM settings? CPU-Z says my "Channels #" is Single however I have both ram chips set up in the dual channel slots of my mobo.
Thanks.
