XBox 360 Lips
18 Oct 2002
Leicester
Evening all...
Does anyone here have lips for the Xbox 360?
My better half complains that while both mics have fresh batteries, are turned on, and register points in a songs contest, the speakers only play the 'singing' from one microphone during the actual song. Both can be heard from the speakers while in the menu.
Is this a problem, or are other people seeing this too?
If I remember correctly you can use the L and R Triggers on a standard controller to move the volume of each mic up and down.
Try this. I imagine one of them may be turned down too low.
Yeah this is the problem, you have to highlight the 'player'at the top of the screen then use the L and R trigger buttons to change the volume from the mic's.
