need help with my birthday present ! (spec me) :D
22 Jun 2005
hey guys, after almost 3 years of having my conroe PC I am finally able to upgrade!
got around 800 quid to spend!
i need it for intense gaming and hd streaming/transcoding! so a powerhouse!
I already have a PSU, case, and a samsung F3 hard drive!
also dont need any peripherals/monitor
Would also love it to be compatiable with my 3d monitor!
so yea! help a nearly 18 year old brother out!
thanks
ive actually forgotten the psu make but its a 650 watt top psu make! so I hope that is enough?
and oh yea sorry I do not need windows 7!
Also,what is you current case and do you already have the Nvidia 3D vision kit? (assuming you are wanting to make use of you minitor for 3D)
If it is a good brand PSU like seasonic, Corsair or Antec you will be fine. Would you be able to dig it out and check the make/model so we can verify it is a good one?
the 3d kit would be gotten seperately so that wouldnt be included in the price!
does ATI not support 3d yet? ive not been around much in the PC scene lately but ive heard ati is superior atm?
ill go check it now :)
enermax eg701ax-ve is the PSU!
also about the 3D part! if the cost of getting a 3d compatiable gfx card outweighs the benefits of getting like a much better non 3d card then id rather get the non 3d card!
You did say around £800. This is what I would buy. :cool:
*OVERCLOCKED* Intel Core i7 920 D0 Stepping (SLBEJ) 4.00GHz / Gigabyte GA-X58A-UD3R Intel X58 Motherboard / Patriot Viper 6GB (3x2GB) DDR3 PC3-12800C9 Tri-Channel DDR3 Bundle
£549.99
Sapphire ATI Radeon HD 5870 1024MB GDDR5 PCI-Express Graphics Card
£318.99
what about that? or is there better value for money?
4 gigs of ram isnt going to cut it i dont think, also want to futureproof it as much as poss!
AMD roadmap shows the AM3 system lasting along time.
I actually like papalazaru suggestion with the cheaper ram.
Its closer to your budget.
Has six cores for your encoding speed.
Will chuck huge frame rates out.
Awesome motherboard.
thanks for help!
hows does amd compare to the i7 though? surely that setup i showed above is as good/better? i can probably go 900 max
ahh how about the 5870 then? is that the best card out there for the price?
i think ill stick to that bundle as it seems a beast!
