image posting
When the link to imageshack opens you should see a browse button under the Welcome to imageshack, no reg required area. Click this and a new window will open to browse your hard drive, find the saved file and upload, imageshack will supply the code which will start with [img
To save a print screen shot of your desktop, paste this to paint and save.
http://img192.imageshack.us/img192/7120/4ghzj.png is the main image page like you said above, so just have
I use tinypic :D
The box i circled is the one you can just copy and paste into the the text box and it will display :D
There's also a neat tool I use called zscreen
http://code.google.com/p/zscreen/
I use a hotkey to take cropped shots of the screen or an active window shot and it automatically uploads to imageshack and puts the direct link in my clipboard. So I just have to click the insert image icon on the forum and ctrl+v
very nifty
so anyway hows those temps for that i7 overclock im better at the hardware stuff than software
Temps are fine :)
very nifty
Going to have try, seems a handy tool :)
very nifty
Ooo nice, i'll get that now :D
rather handy :D (random test)
