Windows 7 Firewall Control - Anyone else use this?
12 Sep 2003
Newcastle, UK
Hi all
Sorry if this has been asked many a time before. Just put it on my PC and it's quite handy. Thought I'd pop on and ask though, do these settings look correct?
Thanks! :)
Oh, link for those that don't have it and would like to try it out:-
http://www.sphinx-soft.com/Vista/order.html
I like the idea of it, but the website puts me off, bigtime :(
It really should have basic outgoing connections built in properly..
I tried it on W7 - it was OK but I ended up removing it and manually control the in built firewall (block outbound connections).
Is the free version of this Firewall Control a 3rd party firewall? Or is it just a nice front end for Windows Vista/7 built in firewall?
Would like to enable some outbound filtering, but when I tried manually configuring Vista firewall it ended up a broken mess. So a prompt with accept or deny would be nice, but I don't want to replace the Vista firewall with something like Comdo and another full replacement.
I think "Windows 7 Firewall Control" is a misnomer, if it's implementing it's own rules then it doesn't really make sense for it to leverage Windows Firewall.
Windows includes a filtering platform which the windows firewall uses, Windows 7 Firewall control uses this same filtering platform, as said before it's basically just a different front end for the built in filtering platform.
