Wireless Keyboard and Mouse advice sought
14 Apr 2010
I am thinking of going wireless on my keyboard and mouse. Any recommendations? Not at all sure on budget but don't want to spend a lot. Thanks
Shame, the shop that were selling logitech dinovo laser desktop have run out, would have suggested that to you for £60!
Would you be using this for gaming? If so I would stay away for wireless, batteries going flat on you halfway into a game is not fun and the lag you can get is very annoying. If you are using this for normal typing then wireless will be fine.
+1 Occasionally had issues midgame or even talking on msn where the keyboard loses connection. Batteries however I've not had a problem with, software usually gives you a fair warning.
I think since last October, I have used about 4-5 sets of batteries, which is good considering it was in use up to 18 hours a day.
A bit of gaming but not much. Quite like the ones with the tiny USB dongle / receiver.
The logitech 1500 comes with a mouse dock to recharge the mouse.
