I bought one of these recently but there's not much tyre clearance from the wheel arch, so the lower straps rub against the tyre slightly as the wheel turns. Anything I can do about this?
Nope that's why i bought the fender bender, does the same job and there's a bit more clearance, important as run a kenda telonix dtc up front in the winter months.
I don't have any tyre clearance issues even when running the 2.4 Rubber Queens. I guess it might make a difference depending on the fork/tyre combination.
