[/QUOTE]
Nice setup. :)
Did you have a problem fitting the memory Airflow Fan as the memory retaining clips on one side of the slots appear not to be the same as on normal boards?
We have been told by Asus we will be getting stock Friday. Will confirm with them tomorrow.
That's great, thanks for the update.We have been told by Asus we will be getting stock Friday. Will confirm with them tomorrow.
i wonder if some1 can answer a question for me >.>
i read the manual and i have a hard time figuring out something.
now in my case i have 8 fans
my cpu cooler has 2 seprate fans(as in 2 noctua fans so two separate pins)
my airflowram cooler fan.
i see only 8 fan sockets on the board, so will i be able to connect 11 fans ?
if yes any1 can assist me what goes where?
for example cpu cooler slot is single but i have 2 cpu cooler fans >.> and so on. would appreciate any help
ah yesthat would make sense probable do that >.> ty for ur reply
, i just wish pinto check the forum soon so we can get some feedback
i still my concern about it not being able to support 6gb ram of the 2000mhz corsair dominators >.> if you look at page 2-17 of the manual, the first one on the list says up to 4gb, what i think they are saying is if you want 2000 mhz on those rams using XMP profile ud better use only 4gb in dual channel , sad
but like mentioned earlier there should be bios updates for this sort of thing :S
