If you use the blue lines as the circuit layout, and you use 6 x AA cells in series, you want 270 Ohm resistors on the single branches and 68 Ohm resistors on the double branches.
All these diagrams are far too complex. It would be easier to use 12 LEDs. Use 4 LEDs in series then use those in parallel. Hard to explain get in touch if you want more help! This is assuming a 12v source with generic LEDs. You can think of 12V LEDs then you just solder them in parallel mate.
Power doesn't matter, you're no where near the limits of 1/4W resistors here, just get the cheapest. Material is the same, and tolerance, the application doesn't call for anything in particular, just go cheap: 1/4W carbon 5%, 330R and 120R.
Just skim read but may have been said. Make sure the LED are wired in the correct way as they are polarity concious and unless they have polarity protection will blow if wired in wrong.
No they won't, they are diodes, most will take far more than their Forward Voltage in reverse bias before they break-down and begin to conduct. If you wire them back to front they just won't light up.
