Can anyone spec me a good PC that will run CS3 smoothly
16 Mar 2010
I use Photoshop CS3 a lot, of late its been slugging on my old PC as Im doing some heavy stuff:
Time for a whole new PC: SPEC ME
Ive got 450 ish to spend. Im guessing I need loads of menory and a pritty good CPU.
All I ever us the PC for is web/watching videos/and Photoshop work
no gaming , got a PS3/360 for that...
SPEC AWAY ;)
THANKS
5770 is an overkill when he's not gaming, better off going for a 4670 as it's half the price and will be far more powerful than photoshop needs.
Good point, that'd probably be the best solution seeing as the 4670 appears to be out of stock.
So no need to go intel ? and how much memory shoould I be looking for ? was think of DDR3 8GB, get a board that can handle 8gb but start with just 4gb ???
Not really a need for Intel if it's just web/office work and Photoshop. 4GB should be fine and you can expand it later if needs be.
