3 May 2010 at 15:29 #1 adbp1 adbp1 Associate Joined 30 Dec 2007 Posts 2,054 Location Oxonfordshire ive got win7 pro 32bit upgrade installed. used to have vista prem 64bit. is there a way to do a proper clean install instead of installing vista then win7.
3 May 2010 at 16:10 #2 theheyes theheyes Soldato Joined 17 Jan 2007 Posts 8,944 Location Manchester http://www.winsupersite.com/win7/clean_install_upgrade_media.asp You took a step backwards with 32bit though.
3 May 2010 at 16:17 #3 robinbredin robinbredin Associate Joined 8 Jan 2009 Posts 1,492 Location Northern Ireland Here is an journal with a step by step approach to using an upgrade copy of win 7, to do an clean install. http://www.sevenforums.com/tutorials/31402-clean-install-upgrade-windows-7-version.html
3 May 2010 at 16:30 #4 adbp1 adbp1 Associate OP Joined 30 Dec 2007 Posts 2,054 Location Oxonfordshire theheyes said: http://www.winsupersite.com/win7/clean_install_upgrade_media.asp You took a step backwards with 32bit though. Click to expand... i know!! but when i ordered i didnt realise then found it was to late.
3 May 2010 at 19:03 #5 ShakenNstirred ShakenNstirred Soldato Joined 5 Jun 2003 Posts 8,732 Location sawley/ long eaton just find some one with a 64bit dvd to lend and use your key with that Last edited: 4 May 2010
3 May 2010 at 19:32 #6 adbp1 adbp1 Associate OP Joined 30 Dec 2007 Posts 2,054 Location Oxonfordshire is that legal? does it actually work?
3 May 2010 at 20:20 #7 ShakenNstirred ShakenNstirred Soldato Joined 5 Jun 2003 Posts 8,732 Location sawley/ long eaton yes its legal(as you have a key that is tied to you not the DVD it comes with) and does work it need to be the same version, ie Home Premium
