Motherboard Sat On Shelf for 6 months, any risk of damage?
26 Jun 2009
Sheffield
Hey, I've been asked to wipe my grandparents computer and reinstall windows.
Thing is, it is powered by an old AMD Sempron 2800+ 2.0ghz, and I have a Socket 478 Pentium 4 2.4ghz HT and motherboard sitting on a shelf in my bedroom where it has beenfor 6 months.
Which would be faster, and would it have sustained any damage there? I've no idea if any static nastiness could have happened to it. It's actually sitting on a cardboard box, not on the shelf itself if that makes any difference.
Mine has been sitting in a dusty metal box with loads of random power things all round it for over a year and it seems to be OK :)
Motherboards are reasonably resilient pieces of kit - I would guess that your motherboard would be fine.
Cheers guys, it'll be worth the change to me if it's only slightly faster, but I'd expect a noticeable difference really seeing as it's a 2.4ghz with HT over a 2.0ghz without....
No idea how the motherboards compare up though really.
You gotta remember these are pretty old. Things were a lot different then, AMD managed good power with low clocks speeds whereas Intel were high clock speeds but I think were roughly same. I don't know that much of that era but I sutainly know it's a lot different now AMD and Intel have had their ups and downs!
Aye I know the tables have turned when it comes to CPUs since then haha.
I read online that a 1.6ghz Sempron is equivilant to a 2.8ghz P4, and I know from personal experience that a 2.4ghz HT is noticably faster than a 2.66ghz none HT, so I reckon there will either be very little difference, or the P4 will be faster.
Think what I'll do is actually test them both and bench it, just out of interest. :P
EDIT: Just realised that the case only takes the motherboard size of the AMD setup, the Intel kit won't fit in it anyway. Looks like it'll just be a case of reinstalling windows and sticking more ram in then. :P
