[TW]Fox;16490178 said:Z4's are awesome!
[TW]Fox;16490188 said:I didnt notice yoursI shall post now
Very nice. Now:
- get a stubby aerial. It's not an RC car
- replace the wheels or get them refurbed (former, if you ask me; if you refurb it will just come back)
- get them done in a darker colour to match the car!
- join z4-forum.com
Done![]()
Lovely. £10,000 with only 38k on the clock, bargain.
Been thinking about an mx-5 but this might change my mind.
<woman mode>
It's too late!
<sulky huff mode>
What other spec did it come with Demon, yours was a bit cheaper than mine and 2/3rds the miles so it definitely looks like a good buy!
Does it have rain sensors/parking sensors etc?
Nice, but noticed a bit of corrosion on your rear 108 style alloys. Common problem, getting mine refurbished soon.
Awesome car! But then I'm biased
What's even better though is the price! Very good deal there if its fully loaded with kit. Does it have the upgraded hifi?
sounds like it has the Carver 10 speaker system
Get yoursef in the oot, lift the carpet out and you should see the amp standing on edge, One one site there should be a small white barcode style label and it will say Carver on it.
Not sure how easy it is to fit the bluetooth to be honest, mine had it and it worked great. Especially with the sat-nav screen.
Can you play music through the bluetooth?
Nope you can't.
I suppose its worth asking them or get a tidy parrot one installed.
First things first.... Get some metal polish on those pipes. Or alternatively buy some facelift exhaust tips from a 3.0si. They were a lot chunkier. MrMason has them on his black Z4 Im sure he'll get you a pic posted.
Someone on the Z4 forum got in touch with a guy called Joe @ www.soperbmw.co.uk - He is parts manager and if you ever need quotes for parts they work out ridiculously cheap compared to my local dealers. Delivered next day too. Just address an email to the parts department, addressing it to Joe and tell him that you contacted him because of feedback from the Z4-forum. You get a reply email instantly with prices. Absolutely fantastic service.
EDIT - Multifunction steering wheel is a nice touch too. I picked mine up for £80 on the z4forum second hand. Took 5 mins to fit.
Does yours have cruise control?
