We can't do it know, have you watched the American army competition, which has the best self controlled cars researched to date.
Sorry, my bad.
What I meant to say was that yes the technology isn't very good now, but in 20-30 years it will be a lot better.
Not entirely, If we had an electric road rather than a mono rail, I would suggest a similar system. Without the tractor.
I was assuming you meant a martial system like that rather than a full one.
In which case we may be arguing for essentially similar systems. Probably using similar sensors (such as those already installed in cars with intelligent cruise control) but you are advocating sensors on the road to lead the cars around (whereas I am advocating GPS/satellite)? Or with an electric road do you still mean using a rail style track?
Yeah it may have been the marital system
(this?) there was a thread on here about it a few months ago? This is the only system that looks like it is possible to run in the next 5 years that i've seen however.
there's lots of ways you could do it pay per mile would be one of them. Tax at the moment is a sliding scale.
What I'm saying is as electricity is so cheap compared to oil and the much higher efficiency there is more than enough money in the system for such a infrastructure once you get it set up.
Personally I think pay per mile would be the best bet, however I know that a lot of motorists, especially those that would use the system the most, don't agree with it (or at least thats the impression I get from this forum) and it would probably have to sit in parallel with another system (for those not using the electricity). I guess another option (just as another option) could be a zoning system, like the underground, but that would probably be a bit too complicated.
The cars are cheap as they are very simple to make, use normal components that are already mass produced. They can be froma couple of thousand (so cheaper than today cars, upwards. Depending what you want.
It is not the case for your system, assuming the technology was perfected all the sensors costs thousands and this would have to be fitted to every car. Rather than the sensors and control being fitted to the infrastructure.
Why would the cars be cheaper than they are today, especially in the beginning? That's before we start taking about choice. Today tou could technically buy a petrol car or around £5k if you really wanted, problem is people don't. If the infrastructure was put in place tomorrow I'm guessing we would still be looking at spending around £15k minimum for a car (for example that ford mentioned earlier in the thread, with an 80 mile range). It has exactly the same issue as my system, the sensors today may cost thousand, but in 10, 20, 30 years? Due to your infrastructure having to be placed over a number of years you would have to start from the other side, cars needing bigger batteries and longer ranges, slowly decreasing as the infrastructure increased (and conversely the cost of the batterys and stuff in the car decreasing). Otherwise, in 10 years time say, you would get a car that ran on electric roads and had an 80 mile range but you couldn't use it north of Luton due to the range off the M25 (for arguments sake the only bit of road upgraded at the time).
Both the electric road and monorail system would have the same problem as well.
With the sensors side of things it would probably take a similar number of years to get a reasonable amount of cars on the road with them in (or able to take advantage of an electric road), the technology would decrease in cost and filter down to lesser cars, much like cruise control and electric windows.
This again is not the case, to be beneficial in traffic flow and congestion reduction, the entire system needs to be integrated centrally at massive cost as well as the massive cost to each car. And then you still have the fuel issue. ATM there is not much on the horizon for battery technology. which leaves hydrogen which is hard to produce or fuel cells., most of which work on bio-fuels which have their own problem.
Although I agree, there may be some benefit to a centrally based system (which you would almost certainly need with an electric road as well), you would still get benefits without it, for example using the same technology that the martial system you mentioned earlier uses. As the speed and distance between cars is computer controlled you would have an almost identical system to it in fact. To the point possibly that the GPS system would not necessarily have to be used on things like motorways, just more minor roads with less traffic.
Yes there is the fuel issue with a non electric road, however you would still have the same issue for at least the next 20 years. As I mentioned before, it would take tens of years to get a reasonable amount of infrastructure in place (just look how long it takes to resurface and widen parts of the M25), until that time (in 20-30 years) your cars would need a similar number of batteries, and by that point the power issue almost certainly won't be an issue..
I have no doubt such system will be possible and in relatively near future. it's just not the system we need, in the time scale we have.
The problem is, neither is yours (in the most part). As I mentioned a few times we are looking at 20-30 years easily before we get enough of the electric road or monorail to actually be of any use.
