OK, so I'm pretty sure it will be warped discs, but thought I'd just check if some more-knowledgeable-types would agree.
Normal braking is fine. Heavy braking is fine up until about 60/70. Heavy braking from 120 feels downright dangerous. There's quite a vibration above the 60/70 mark that gets worse with speed. I assume this is going to be warped discs as opposed to pad knock-off (whatever that is) or any other pad-related issue?
It'll be infuriating seeing as they were only put on last June
Cheers
Cheers
Of course there are.
