Have you set memory settings correctly?
Those will easily keep trashing stability regardless how good CPU is if they're wrong.
3.4GHz might be tweakable for 1.15V considering how I accidentally forgot Vcore around 1.13V while increasing FSB and how Prime started giving errors faster only near that clock.
P5Q deluxe, NB 1.24, VTT 1.24 and PLL 1.56 (GTLs and FSB strap at auto)
Running 1.25VID chip at 3.7GHz and 1.2V in here...As you can see the vid for the chip is 1.1375v and he has it set @ 1.192v to get 3.4ghz, does that seem reasonable?
