Caporegime
- 13 May 2003
- Warwickshire
Yeah, but you're expecting a plane, which in in the process of crashing to maintain its transmission dish trained on a stationery sattellite, to keep the information flowing? Where exactly are you intending on putting the dish anyway? You cant exactly put it externally, that would play hell with the aerodynamics, and internally is going to take up valuable space.
Satellite data transmission isn't some kind of manual process whereby you need a guy in a hi-vis jacket and gloves constantly adjusting the thing depending on the angle of the plane. Do you have to keep moving your SatNav around as you drive round the country?
