Spec me... a drink!
22 Jan 2008
Sheffield
Hello all, coming up to our last night at university tonight so going to do what is expected of me and to get absolutely smashed :D
My normal pre drink of choice Sainsbury's basic vodka and coke which is about £7.50 and lasts me two nights out usually.
I have £15 which I can afford to spend on something to drink before we go out and need some help! Things outside the box are OK however I don't really enjoy beer and cider anything else is fine
The task is outlined as follows
- £15 max
- Be able to purchase from a normal sized supermarked / boozebusters etc place
- Able to be mixed coke/lemonade etc
Go!
If you are looking for two smashings for under £15 and ruling out cider then cheapo vodka is hard to beat.
As an out of the box suggestion I would suggest port, if you are mixing with lemonade then cheapest will be fine, a few pints of a 50/50 mix with lemonade is tasty enough to drink like squash and will get you well on the way. should be able to pick up two half decent or three 'drinkable' bottles for your budget.
stick with vodka but buy a better one ! and add cloudy lemonade if you need/want a mixer
Finlandia Grapefruit Fusion is currently £12 a bottle in Sainburys. Buy 3 of their bottles of slimline tonic for £1.20.
£1.80 change. And the most amazing vodka I have had that is not super premium. :)
Seeing as it's just one night, you don't need two night's worth? Go for some JD or SoCo (500ml if budget comes first):D
Stick with a good vodka, I.e Smirnoff, and get something a bit different to mix it with, If i am planning on getting smashed i will normally get a couple of big cans of energy drive (monster, Relentless) and then some mixer other than boring coke or lemonade, Very nice with fanta fruity, dr pepper or iron bru.
