Suggestion on gfx card?
If you can stretch to the 5770, that would be the best bet.
Failing that a second hand 260GTX, 4870 or 4890 1GB maybe.
BTW your sig is far too big ;)
Depending on cpu speed etc as mentioned above I'd consider a 5770 (if dx 11 is a requirement), or a 4890. Both cards overclock well.
lol
mobo is sort of relevant but not really....and the case is totally irrelevant. That's like answering "where do you live?" with "a land mass on a planet somewhere".
Asus Rampage II Extreme
Coolermaster CM 690 Advanced
Coolermaster 850W Silent Pro
i7 - 920
GFX Card: thats what i'm looking for?
I will not be overclocking this system, i might but very rarely.
ok good that's the sort of info we were looking for.
I assume this is for games? If so then your best bet is a 2nd hand 4890 or GTX 260 216 as stated.
Otherwise the 5770 is pretty good but around 20-30 above your budget. The next best thing would be a 4870 1GB
that mobo supports crossfire and sli, so a gtx260 sli at a later date or 4870/4890 for crossfire. second hand cards can be found on famous auctions sites or the loot.
