If you went for the Athlon II X3 based build you could get an HD4850 1GB from OcUK:
http://www.overclockers.co.uk/showproduct.php?prodid=GX-007-HS&groupid=701&catid=56&subcat=938
As you can get free postage from OcUK the complete upgrade should be just under £250.
Most reviews have pitted the HD5750 1GB against the HD4850 512MB. If you are using XP still you can only use DX9 as DX10 and DX11 require Vista or Windows 7. In DX9 and DX10 games both the HD4850 1GB and the HD5750 1GB should be quite similar in performance IMHO.
I assume you have a copy of an OS to install?
OcUK sell neither 2GB DDR3 or a 435, so having to go with a competitor
Have Vista, I believe I have another install left on that registration key!
As long as the mobo supports unlocking that is !
