that's what I got from it when i read it.
although it has been nearly 3 years since i last read the bible.
what's the bible like to read???
He didn't do it for the lulz, however.
Look at the places and the people he wiped out. They were described in the Bible as being "all bad, all the time" (paraphrasing). The world before the flood was apparently almost in chaos.
Similarly, Soddom and Gommorah were apparently lost causes. I'd have to look it up to find out exactly what they were doing there, but again the Bible is pretty damning. Bear in mind there are relatively few examples of places being totally wiped out. It suggest these places had fallen into a state of extreme depravity.
Also in Egypt's case the killing of the first born was the last plague, was it not. They had plenty of demonstrations of God's power before that, but each time they basically chose to ignore the warnings and act in opposition to him.
It's interesting to note that even the death of all their firstborn didn't make them see sense, they still carried on in defiance and this lead to further loss of life on their part (when a lot of their military was drowned).
The recurring theme in all cases is that God sends a clear warning first... and that these warnings are seldom heeded.
God grants free will, we cause suffering.
Well in fact God didn't cause anything bad to happen to Job. It all started as a challenge that Satan made to God, saying "Job only worships you because you've given him everything a man could want. I bet if you take these things away from him he'll curse you to your face. No one would worship you if you didn't bless them as a result."
So God said to Satan "Do what you like to him, but don't kill him. We'll see if your theory is correct."
And then Satan did a whole bunch of craptastic things to Job. When he was done, and Job hadn't cracked, the Bible says God gave him back everything he'd had before and more.
And of course all his family that were killed still have the chance of being resurrected by God in the future.
So God didn't cause Job's suffering. I'd brush up a bit on Biblical accounts before you attempt to use them in arguments.
I didn't say he did. I in fact was incredibly precise not to make any moral judgement at all. I answered the question "Does God cause suffering?" using the bible as evidence.
So every first born in Egypt was all bad all the time? Even the ones just born? So everyone prior to the flood was all bad all the time? Even the ones just born?
Suggest all your like, there is little proof of it and it would also beggar belief that all the inhabitants were so totally depraved, especially the children.
He killed innocents to prove a point. He caused suffering.
Isn't it a standard thing to not negotiate with terrorists? Not give in to their demands?
Moot point. He caused suffering. Question answered in the positive.
Death is not the end. You all seem to be forgetting this.
Why do you think so many are happy to die instead of renounce their faith? They believe that God has power over life and death. Those who die in innocence (including children & the unborn) - regardless of who kills them - can be resurrected to life.
When you look at it that way it isn't odd at all. Their deaths are only temporary.
God can cause suffering, this is in extreme cases but there are still some, and yes they are mainly in America.
I've read of few cases in which parents decide not to take their children to the hospital because they believe god will heal their child instead of seeking the real medical treatment they need. In these cases the children normally die, which is due to the belief and the falsified faith that the parents are given. Obviously this is an extreme case and does not happen every day, but it still does happen. There is also cases of people turning down treatments because they believe god will help them through illness, and they disregard real things which can save their lives like operations and treatments.
Most people who believe in god are more comforted by the fact 1 day, when they die, they will be "with god". This takes away 1 of the fears that every human being has, in this aspect the belief in god is completely acceptable, because it's not easy for anyone to accept they will die, and if belief in a god can help them accept what's going to happen then so be it. But the original question of "Does god cause suffering?" the answer is "Yes" but only in extreme cases and it's not in an every day scenario that the belief in him would.
You're right giving a man a gun and saying go for it murder the lot of them is morally fine especially if you have the power to prevent it.
That isn't really God causing suffering, that is peoples belief in God causing suffering.
I know, but it's due to god that they have the belief, which is why in these such cases they turn down treatments.
God can't have a direct impact on a human, the only link between a god and humans is a belief in him, and if this belief shrouds and clouds your judgement of what should be done at what moments then it can end up with people suffering in the process.
