It was me who posted thatSomeone posted benchmarks of Cryis running Q6600@stock, Q6600@3ghz and [email protected] amongst other CPUs. Results showed that with similar setup a faster CPU increases FPS by quite a lot (if not bottlenecked by other hardway, the GPU)
On a P45 it can do 400 FSB on stock volts. Drop the multi and you are running 3.2 GHz with nice 400 FSB to alleviate any potential bottlenecks.
Course if you are talking about cpu clock speed then thats another matter![]()
Actually the reason why Q6600 overclocked to 3.7GHz is bottlenecking the 5870 in Crysis is because the game was not optimised for Quad (you can see i3 530 at 4.07GHz got identical frame rates to Phenom II 965BE at 3.99GHz), not because of resolution being at 1680x1050 instead of 1920x1200. The frame rate of 33min, 57average is the GPU bound of 5870 at those settings.You might see marginally higher FPS, but not much. That review shows the difference between 2.4Ghz, and 3.7Ghz, due to diminishing returns and GPU limits, the first 600Mhz would give massively more performance than that last 700Mhz, as you can see by the results of similar chips but in dual core, at 3Ghz being noticeably faster.
But the point of CPU REVIEWS is they ALWAYS show at less than gpu limited resolution/situations on purpose to highlight the difference. Its a 5870, at 1920x1200(almost standard resolution for that power of card) those results would be hugely closer and a 3Ghz Q6600 is likely to be very close to the 4.15Ghz i5 result.
Is you memory 667MHz or 800Mhz? If it is 800MHz, you could try lowering the multipler to x8 and use 400FSB (if you motherboard let you), that way you would have Q6600 at 3.2GHz and RAMs at 800MHz at 1:1.thanks for the info,ill try clock it to 3.2GHz,at stock volts,just buy increasing my fsb,and putting the ram at 667mhz,
will 360mhz give me 3.2GHz,thanks.
You might need to raise the vcore by 1 step up at a time if you can't stable it on stock voltage. Run Prime95 for an hour or something (and if the voltage isn't enough, you would get BSOD and PC reboot in under 15mins anyway).
My crappy nforce board need +0.05v to get my Q6600 stable at 3.15GHz at 9x350, ram 800MHz, FSB: DRAM 1:1. My board would become unstable at over 350FSB even if I add extra voltage...it must be the low FSB wall imposed nforce chipset that everyone's talked about.
What motherboard you got by the way?
Also, rather than just overclocking your CPU, you should try overclocking your 9800GTX+ as well. MSI Afterburner is good and easy to use.
