- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
We have 31 great new deals on This Week Only
AMD Phenom II X4 Quad Core 955 Black Edition 3.20GHz (Socket AM3) - Retail @ £127.98 inc VAT
The AMD Phenom II processors are the most advanced processors for true multitasking offering true quad-core design. AMD Phenom II processors deliver virtually uninterrupted information flow between processor cores, main memory and graphics and video accelerators for amazingly rapid system response and phenomenal system performance. AMD Phenom II processors deliver unbeatable multi-core value with superior high definition computing, advanced multitasking performance, and innovative, energy efficient solutions.
- 3.20GHz clock speed
- 2MB L2 cache
- 6MB L3 cache
- DDR3-1333 support
- 45nm process technology
- True Multi-core Processing
- Direct Connect Architecture
- Integrated Dual-Channel Memory Controller with up to DDR3-1333 support
- HyperTransport 3.0
- AMD Balanced Smart Cache
- AMD Wide Floating Point Accelerator
- AMD Memory Optimizer Technology
- AMD Digital Media Xpress 2.0
- AMD Virtualization with Rapid Virtualization Indexing
- Cool‘n’Quiet 3.0 technology
Only £127.98 inc VAT.
ORDER NOW
Antec 300 Three Hundred Ultimate Gaming Case - Black @ £42.98 inc VAT
Impressively spacious and unbeatably reliable, the Antec Three Hundred is an unbeatable enclosure. Despite its eminently portable frame, the Three Hundred has enough room for all the latest flag-ship graphics cards, as well as six hard drives and a standard ATX motherboard. A cable management compartment keeps your system organized and the airflow unobstructed. A 120mm rear fan and 140mm top fan ensure that the case runs cool even when playing the most demanding games, while the sleek black finish gives it an extra stylish edge.
- External 3 x 5.25"
- Internal 6 x 3.5" for HDD
- 1 rear 120 x 25 mm TriCool™ Fan with 3-speed switch control.
- 1 top special 140 x 25 mm TriCool™ Fan with 3-speed switch control
- 2 front (optional) 120 mm fans to cool the hard drives
- 1 side (Optional) 120 x 25 mm Fan to cool graphic cards
- Washable air filters reduces dust build up in your system, which helps keep your system cooler
- Perforated front bezel for maximum air intake
- 7 expansion slots
- Top mounted I/O ports for easy access
- 2 x USB 2.0
- Dimensions: 458mm (H) x 465mm (D) x 205mm (W)
- HDA & AC’97 Audio In and Out
Only £42.98 inc VAT.
ORDER NOW
Corsair Obsidian 800D Full Tower Case - Black @ £214.99 inc VAT
Designed for Years of Performance
The Obsidian Series 800D is built to last through years of motherboard, power, memory, cooling, and component upgrades.
The steel structure has a matte black coating both inside out and is finished with a brushed aluminum faceplate for a professional look that’s both serious and awe-inspiring. A windowed side panel makes it easy to show off your work.
Three Isolated Cooling Zones
The power supply compartment, main compartment and the SATA bays each have dedicated cooling subsystems to prevent heat buildup.
A dust-filtered 140mm fan draws in cold air at the bottom of the chassis and exhausts it at the rear and top. This clever design forces fresh air directly over the graphics card and CPU. The SATA hot-swap bays are cooled by a separate 140mm fan which vents from the chassis via a sealed chamber and prevents the heat generated by the drives from entering the main compartment. The power supply compartment has its own dedicated intake and exhaust, also isolated from the main compartment.
Need even more cooling performance? The Obsidian Series 800D has pre-drilled support for top-mounted single, dual, and triple radiators, or up to three additional 120mm fans.
Advanced Features for Extreme Flexibility
A four-drive SATA hot-swap drive bay sits in the front of the case, making it easier to install or swap hard drives on the fly. A unique cable routing system virtually eliminates cable clutter that can impede airflow. The tool-free design allows for easy entry, easy access, and quick installation of 5.25” drives.
- Four easily accessed hot-swap drive bays
- Removable CPU backplate panel for easy heatsink installation
- Isolated cooling zones prevent heat buildup
- Unique cable routing holes guarantee a clean and clutter-free installation
- Three fans included, with the ability to add four more 120mm fans
- Tool-free optical drive installation makes building a system faster than ever
- Two year warranty with Corsair’s world-class customer service and technical support
- Dimension: 609mm X 609mm X 229 mm
- 5 x 5.25" Drive Bays
- 4 x 3.5" SATA Hot Swappable Bays
- 2 x 3.5" Internal Bays
- Cooling: 3 x 140mm fans (included)
- Cooling: 4 x 120mm fans (optional)
- Front I/O: 4x USB 2.0, 1x FireWire, 2x Audio
Only £214.99 inc VAT.
ORDER NOW
Corsair XMS3 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMX4GX3M2A1600C9) @ £105.99 inc VAT
This 4GB twin kit memory solution has been designed specifically to support the Intel Core i5 and Core i7 dual channel memory DDR3 solutions. This solution runs at an incredibly fast 1600MHz at CAS latency of 9-9-9-24. So not only do you get to run your Intel Core i5 or Core i7 dual channel memory system at 1600MHz but with these tight Latency timings your system performance will rock..
- 4GB memory kit (2 x 2GB) for use with Dual Channel DDR3 Intel Core i5 and Core i7 processors
- 1600MHz
- Latency of 9-9-9-24 for maximum reliability and performance
- Intel XMP (Extreme Memory Profile) Support
- XMS Heat Spreader
- Limited Lifetime Warranty
Only £105.99 inc VAT.
ORDER NOW
Corsair XMS3 6GB (3x2GB) DDR3 PC3-12800C9 (1600MHz) Tri-Channel (TR3X6G1600C9) @ £142.99 inc VAT
The XMS Series TR3X6G1600C9 is a 6144MByte kit of DDR3 SDRAM DIMMs built using Corsair’s high performance heat sink which includes Intel’s Extreme Memory Profiles (XMP 1.2). This part delivers outstanding performance in the latest generation of X58 DDR3-based motherboards. It has been tested extensively in popular X58 motherboards to ensure compatibility and performance at its rated speed. This memory has been verified to operate at 1600MHz at latencies of 9-9-9-24 at 1.65V VDIMM.
- Each three module set is tested at 1600MHz
- Packaged together immediately following system test
- Tested together at 1600MHz, Vdimm = 1.65V, at latency settings of 9-9-9-24 on Intel X58 DDR3-based motherboards.
- SPD programmed at: JEDEC standard 9-9-9-24 values at 1333MHz.
- XMP 9-9-9-24 values at 1600MHz, 1.65V
- 6144 Megabytes of DDR3 memory
- Three matched 2GB modules
- 100% tested at 1600MHz in X58-based motherboards
- Supports Intel Extreme Memory Profiles (XMP)
- Lifetime Warranty
Only £142.99 inc VAT.
ORDER NOW
Creative Sound Blaster X-Fi Titanium - Fatal1ty Professional Series 7.1 Sound Card (70SB088600000) @ £99.99 inc VAT
Creative's Sound Blaster X-Fi Titanium - Fatal1ty Professional Series is the Pro Gamer's choice for sound! Its new PCI Express chipset with hardware-accelerated EAX 5.0 and OpenAL gaming is designed to give you the winning edge on the latest PCs. Combined with Xtreme Fidelity technologies for accurate and immersive 3D positional audio even over headphones, it's the ultimate gaming solution under Windows XP and Vista. Onboard Optical I/O and real-time Dolby Digital encoding give you single cable connectivity to your surround sound decoder, and PowerDVD software plays your Dolby Digital or DTS movies in incredible surround sound over headphones or speakers.
- New Sound Blaster X-Fi PCI Express chipset for the latest PCs.
- Hardware-accelerated EAX 5.0 and OpenAL gaming with 64MB X-RAM, for ultra-realistic cinematic in-game audio. Creative ALchemy software restores EAX surround sound to Windows XP games under Windows Vista.
- Accurate and immersive X-Fi CMSS-3D surround sound over headphones for online or late night gaming sessions.
- On-board optical I/O with Dolby Digital real-time encoding, for single cable connection to your surround sound decoder.
- UAA (Universal Audio Architecture) design ensures maximum compatibility in Windows Vista.
- PowerDVD software for Dolby Digital or DTS movies in incredible surround sound over headphones or speakers. THX certification assures high-fidelity results, and low-latency ASIO drivers make this card ideal for the music enthusiast.
Only £99.99 inc VAT.
ORDER NOW
Gigabyte GA-X58A-UD3R Intel X58 (Socket 1366) DDR3 Motherboard @ £151.99 inc VAT
Based on the Intel X58 chipset, the Gigabyte GA-X58A-UD3R delivers all the killer next generation features that gaming enthusiasts and power users have been waiting for including Gigabyte's 333 Onboard Acceleration features with support for USB 3.0, SATA Revision 3.0 (6Gbps) and a 3x USB Power Boost, as well as multi-GPU support for NVIDIA 3-Way SLI and ATI CrossFireX and support for Intel's high performance processors offering a high level of future CPU headroom for users wanting to maintain cutting-edge levels of performance. With the memory controller integrated directly into the processor die, the Gigabyte GA-X58A-UD3R also supports triple channel DDR3 memory for blazing fast memory performance.
- 2x USB 3.0
- 2x SATA 6Gb/s (RAID 0 and 1)
- CPU: Intel Core i7 Processors (Socket LGA1366)
- Chipset: Intel X58 Express / ICH10R
- Memory: 6x DDR3 DIMM 2200 / 1333 / 1066 / 800 MHz (Max. 24GB) / Tri-Channel / Intel Extreme Memory Profile (XMP)
- Expasion slots: 4x PCIe 2.0 x16 Slots, 2x PCIe x1 Slots & 1x PCI Slot (Supports ATI CrossFireX & NVIDIA SLI Technology)
- Storage: 1x Floppy, 1x Ultra DMA 133/100/66, 8x SATA 3Gb/s (RAID 0, 1, 5 and 10) & 2x eSATA 3Gb/s
- LAN: RTL8111D Gigabit LAN
- Audio: ALC889 8-channel High Definition Audio CODEC
- 10x USB 2.0
- 3x IEEE 1394a
- 1x PS/2 Keyboard
- 1x PS/2 Mouse
Only £151.99 inc VAT.
ORDER NOW
Intel Core i7 980X 3.33GHz (Gulftown) Extreme Edition (Socket LGA1366) - Retail @ £869.98 inc VAT
Dominate your gaming competition with the unlocked, unleashed and uncompromised Intel Core i7 Extreme Edition. Thanks to the latest ultra-threaded, killer combination of smart features, including Intel Turbo Boost Technology and Intel Hyper-Threading Technology, the Intel Core i7 Extreme Edition is Intel’s most capable and downright devastating PC processor ever.
- Core Size: 32nm
- Socket: LGA1366
- Six Core
- Frequency: 3.33GHz
- Multiplier: 25x
- L2 Cache: 6x 256KB
- L3 Cache: 12MB
- QPI: 6.4 GT/s
- TDP: 130W
- Includes Heatsink & Thermal Paste
Only £869.98 inc VAT.
ORDER NOW
OCZ Gold 6GB (3x2GB) DDR3 2000MHz PC3-16000C10 Low-Voltage Triple Channel (OCZ3G2000LV6GK) @ £168.99 inc VAT
The OCZ PC3-10666 triple-channel memory kit is designed specifically for the Intel Core i7 processor / Intel X58 Express Chipset. Optimized for the Core i7’s triple channel mode, these new 6GB kits ensure optimal performance via an ideal combination of low voltage requirements, speed, and latency. Developed for enthusiasts and early-adopters, the low voltage OCZ Triple Channel solutions are the choice counterparts for leading-edge performance that won’t inhibit the functionality of Core i7 CPUs. In addition, modules are tested in matched triplets ensuring superior compatibility. OCZ’s Triple Channel kits are 100% hand-tested for quality assurance and compatibility and feature propriety XTC (Xtreme Thermal Convection) heatspreaders for the most effective heat dissipation. Furthermore, each OCZ memory module is backed by the industry leading OCZ Lifetime Warranty and technical support for unparalleled peace of mind.
- 2000MHz DDR3
- CL 10-10-10-20 (CAS-TRCD-TRP-TRAS)
- Gold Z3 XTC Heatspreader
- Lifetime Warranty
- 1.65 Volts
- 240 Pin DIMM
Only £168.99 inc VAT.
ORDER NOW
OCZ Gold Low Voltage 4GB (2x2GB) DDR3 PC3-12800C8 1600MHz Dual Channel Kit (OCZ3G1600lV4GK) @ £89.98 inc VAT
OCZ low-voltage DDR3 kits are designed specifically for the Intel® P55 Chipset and subsequent Intel® Core™ i7, i5, and i3 (Socket 1156) processors. Configured for dual channel mode, these ultra-compatible 4GB kits ensure optimal performance with an ideal combination of low power requirements at 1600MHz. Developed for cost-conscious enthusiasts and gamers, these new OCZ modules were engineered with the same affordability and performance standards as the new Lynnfield platform. By using sophisticated IC screening methods and qualifying on a variety of motherboards, OCZ low-voltage kits are the perfect complement for the P55 Chipset and choice CPU to deliver the maximum stability. Together, P55 and OCZ memory are the premium option for the midrange desktops. OCZ DDR3 PC3-12800 Gold Low Voltage Dual Channel Kits are 100% hand-tested for quality assurance and feature propriety XTC (Xtreme Thermal Convection) heatspreaders for the most effective heat dissipation. Furthermore, each OCZ memory kit is backed by the industry-leading OCZ Lifetime Warranty and technical support for unparalleled peace of mind.
- 1600MHz DDR3
- CL 8-8-8-24
- Available in 4GB optimized kits
- Unbuffered
- Gold Layered Z3 XTC Heatspreader*
- Lifetime Warranty
- 1.65 Volts
- 240 Pin DIMM
Only £89.98 inc VAT.
ORDER NOW
OCZ StealthXStream 500w Silent Power Supply @ £41.98 inc VAT
Designed for the value-minded gamer seeking simple, quiet performance, the StealthXStream includes OCZ’s acclaimed reliability and feature-sets with a lower price point. Ideal for system builders and enthusiasts who prefer a low-key PSU, the StealthXStream focuses on performance, quality, and quiet operation. Even at peak loads, the 500W StealthXStream remains virtually silent and excludes flashy LEDs ensuring the power supply is not seen or heard. The StealthXStream is kept supremely cool with a large 120mm fan features a standard ATX power supply form factor resulting in a compact footprint to accommodate virtually all computer towers. With a sustained output of 500W and four +12V rails to provide uniform distribution of power, the StealthXStream is well-suited for and driving today's higher end systems. The rock solid StealthXStream is built to provide sufficient output to power dual GPU and CPU platforms, complete with two PCI-Express cables and a 4/8 CPU auxiliary connector which are wrapped in a flexible mesh promoting a tidy environment inside the case. The OCZ StealthXStream provides Universal Input and Active PFC (Power Factor Correction) to effectively regulate input voltage across worldwide power grids and maintain an economical, yet stable supply of power. All OCZ StealthXStream power supplies come backed with an industry-leading three year OCZ PowerSwap Warranty for the ultimate peace of mind.
- 500W Configuration
- OCZ PowerWhisper™ Technology
- Internal 120mm fan
- 3 year warranty backed by OCZ’s exclusive PowerSwap™ replacement program. No more endless return-for-repair loops!
- 150 x 140 x 86mm 1 x 20+4Pin ATX
- 1 x 4-pin CPU
- 1 x PCI-E 6+2 pin
- 4 x 4-pin Molex peripheral
- 1 x 4-pin floppy
- 2 x S-ATA
- High efficiency
- 80% @ 115V (Typical load)
- 83% @ 230V (Typical load)
- Overvoltage/Overcurrent/Short-Circuit protection
- Active PFC
- MTBF:100,000 hours
- 100~240Vac 10-5A 50/60Hz
- +3.3V(36A), +5V(30A), +12V1(18A), +12V2(18A), +12V3(18A), +12V4(18A)
Only £41.98 inc VAT.
ORDER NOW
OCZ Vertex Limited Edition 50GB 2.5" SATA-II Solid State Hard Drive (OCZSSD2-1VTXLE50G) @ £155.99 inc VAT
OCZ Technology’s latest ground-breaking solid state drive is taking shape in a limited edition solution designed for consumers looking for the highest level of SSD performance. Pushing the envelope like never before, the OCZ Vertex Limited Edition surpasses the competition where it counts most: maximum read/write speeds, unparalleled 4k random write rates, and minimal performance degradation. With performance that takes centre stage, the Vertex LE series doesn’t lose sight of what makes an SSD the ideal storage alternative to hard drives and delivers the quality, reliability, and durability demanded by consumers that will not settle for anything but the best. Complete with TRIM support, Vertex LE is the ultimate Windows 7 notebook or desktop upgrade.
- Capacity: 50GB
- Maximum Read: 270MB/sec
- Maximum Write: 250MB/sec
- Sustained Write: 235MB/sec
- Max I/O Per Second (IOPS): 50000 IOPS (4KB File)
- NAND Flash: Multi-Level Cell (MLC)
- Interface: SATA-II
- TRIM Support (Requires Windows 7)
- Warranty: 3 Years
Only £155.99 inc VAT.
ORDER NOW
Point Of View GeForce GTX 480 1536MB GDDR5 PCI-Express Graphics Card @ £439.98 inc VAT
Next generation gaming has arrived. Nvidia GeForce GTX 480 gives your games an adrenaline shot with the world's fastest performance and futuristic, visually stunning graphics. Experience heartpounding, cinematic visuals on your favorite games with the combined power of DirectX 11, CUDA and Nvidia PhysX technologies. And expand your visual real estate across three HD displays in jawdropping stereoscopic 3D for the ultimate in immersive gaming. Nvidia GeForce GTX 480: pure adrenaline meets visual bliss.
- Core Clock: 700MHz
- Memory: 1536MB GDDR5
- Memory Clock: 3696MHz (Effective)
- Memory Interface: 384-Bit
- Processing Cores: 480
- Shader Clock: 1401MHz
- Bus Type: PCI-Express 2.0
- Display Connectors: 2x Dual-Link DVI-I & 1x Mini-HDMI 1.3a (Includes HDMI & VGA Adapters)
- SLI Ready
- HDCP Capable
- DirectX 11 Support
- OpenGL 3.1 Support
- PhysX Enabled
- CUDA Enabled
- Warranty: 2 Years
Only £439.98 inc VAT.
ORDER NOW
Sapphire ATI Radeon HD 5850 Toxic 2048MB GDDR5 PCI-Express Graphics Card @ £301.42 inc VAT
The Sapphire HD 5850 TOXIC Edition is a Sapphire original design based on the latest 40nm graphics architecture from ATI. Featuring 1440 stream processors and 72 texture units, it delivers the fastest performance in class as well as supporting ATI Stream technology. It fully supports the advanced graphical features of DirectX 11, and deliver spectacular video clarity, speed and visual effects, including over multiple monitors. Designed for the enthusiast user, the SAPPHIRE HD 5850 TOXIC Edition is factory overclocked to 765MHz core and 1125MHz (4500MHz effective) memory speeds. Sapphire’s World leading Vapor-X technology not only allows the card to run up to 15c cooler and 10dB quieter than the standard models, it provides additional headroom for further performance tuning.
- Core Clock: 765MHz
- Memory: 2048MB GDDR5
- Memory Clock: 4500MHz (Effective)
- Processing Cores: 1440
- Bus Type: PCI-Express 2.1
- Display Connectors: 2 Dual-Link DVI-I, 1 HDMI & 1 DisplayPort
- HDCP Capable
- OpenGL 3.2 Support
- ATI CrossFireX Ready
- ATI Eyefinity Technology
- ATI Avivo HD
- ATI Stream Technology
- Warranty: 2 Years
Only £301.42 inc VAT.
ORDER NOW
Sapphire ATI Radeon HD 5870 1024MB GDDR5 PCI-Express Graphics Card @ £318.99 inc VAT
Prepare to experience a riveting high-definition gaming experience with the ATI Radeon HD 5800 Series graphics processors. Expand your visual real estate across up to three displays and get lost in the action with revolutionary ATI Eyefinity Technology. Using ATI Stream technology, accelerate even the most demanding applications and do more than ever with your PC. The first to deliver full support for Microsoft DirectX 11, these GPUs enable rich, realistic visuals and explosive HD gaming performance so you can dominate the competition.
- Core Clock: 850MHz
- Memory: 1024MB GDDR5
- Memory Clock: 4800MHz (Effective)
- Memory Bandwidth: 153.6GB/s
- Processing Cores: 1600
- HDCP Capable
- ATI Avivo HD
- Includes: Colin McRae DiRT 2
- Warranty: 2 Years
Only £318.99 inc VAT.
ORDER NOW
Sapphire ATI Radeon HD 5970 2048MB GDDR5 Graphics Card @ £485.98 inc VAT
The fastest graphics card on the planet, the ATI Radeon HD 5970 delivers an unrivaled HD gaming experience so you can play the latest, most demanding HD titles like never before. Engineered for speed, this next-generation powerhouse delivers unprecedented performance straight out of the box. Unlocked, this graphics card has massive headroom so you can take control and push your hardware to its full potential! Expand your visual real estate across up to three displays and get lost in the action with ATI Eyefinity Technology. Using ATI Stream technology, accelerate even the most demanding applications and do more than ever with your PC. Among the first to deliver full support for Microsoft DirectX 11, these GPUs enable rich, realistic visuals with explosive performance so you can dominate your gaming competition.
- Core Clock: 725MHz
- Memory Clock: 4000MHz (Effective)
- Memory Bandwidth: 256GB/s
- Processing Cores: 3200
- Display Connectors: 2 Dual-Link DVI-I & 1 Mini DisplayPort
- HDCP Capable
- ATI Avivo HD
- Warranty: 2 Years
Only £485.98 inc VAT.
ORDER NOW
Sony Optiarc DRU-870S 24x DVD±RW SATA ReWriter (Black) - Retail @ £22.98 inc VAT
The DRU-870S DVD/CD rewritable drive from Sony Corporation is designed to meet today’s data storage demands on systems with available internal S-ATA port.
It provides the industry’s fastest level of Write speed (up to 24x on DVD+/-R media) whilst supporting all key DVD/CD format (DVD+/-R, DVD+/-R DL, DVD+/-RW, DVD-RAM, DVD-ROM, CD-R, CD-RW and CD-ROM), making it ideal for a variety of applications such as data back-up, data archiving, digital image storing, video content archiving and sharing this content. The drive comes with the award winning Nero 8 Express DVD/CD mastering software and is certified for the usage with Windows® XP or Vista.
Write Speed
- DVD-R: 24x
- DVD+R: 24x
- DVD-R DL: 12x
- DVD+R DL: 12x
- DVD+RW: 8x
- DVD-RW: 6x
- CD-R: 48x
- CD-RW: 32x
Read Speed
- DVD-R: 16x
- DVD+R: 16x
- CD-R: 40x
Only £22.98 inc VAT.
ORDER NOW
Western Digital Caviar Black 1TB SATA 6Gb/s 64MB Cache - OEM (WD1002FAEX) @ £79.99 inc VAT
WD Caviar Black high performance 3.5" SATA hard drives combine 7200RPM spin speed, 64MB cache, SATA 6Gb/s interface with an integrated dual processor for lightning-fast performance in demanding desktop, workstation, and multi-drive systems. Rock solid mechanical architecture and enhanced reliability features help protect the drive and the data stored on it. Backed by a 5-year limited warranty.
- Capacity: 1TB
- Cache: 64MB
- Interface: SATA 6Gb/s
- Spin Speed: 7200RPM
- Warranty: 5 Years
Only £79.99 inc VAT.
ORDER NOW
XFX ATI Radeon HD 5770 "AVP Edition" 1024MB GDDR5 PCI-Express Graphics Card @ £132.99 inc VAT
Now, more people than ever can experience real innovation in DirectX 11 gaming with ATI Radeon HD 5700 Series graphics processors. Loaded with advanced technology, these GPUs have the power and premium features you need for fully immersive gameplay. Expand your visual real estate across up to three displays and get lost in the action with revolutionary ATI Eyefinity Technology. Using ATI Stream technology, accelerate even the most demanding applications and do more than ever with your PC. The first GPUs in this class to offer full support for DirectX 11, these GPUs enable rich, realistic visuals and explosive HD gaming performance so you can dominate the competition.
- Memory Bandwidth: 76.8GB/s
- Processing Cores: 800
- HDCP Capable
- ATI Avivo HD
- Warranty: 2 Years
- Comes with Full Copy of AVP (Download Voucher)
***EXCLUSIVE Premium Priority 2 Year Warranty***
In the unlikely event of your card failing within 2 Years, OcUK will replace your card with a brand new one, pending testing within our standard RMA terms and conditions (http://www.overclockers.co.uk/support.php)
Only £132.99 inc VAT.
ORDER NOW
Zalman CNPS10X Flex CPU Cooler (Socket 754/939/AM2/AM2+/AM3/775/1156/1366) @ £22.98 inc VAT
Introducing Zalman's third and final cooler to sport the CNPS10X moniker, the CNPS10X FLEX. The FLEX (or flexible) version is supplied without fans. This gives you the flexibility to use any 120mm fan(s) you see fit.
Also with the FLEX it is possible to install up to two 120mm fans unlike the EXTREME and QUIET versions which only can accommodate a single 120mm fan, giving you the potential to have either an extremely quiet CPU cooling solution or one that provides powerful cooling.
- Socket Compatible: 939 / AM2 / AM3 / 775 / 1156 / 1366
- Dimensions: 133 x 74 x 151mm
- 5 U shaped heatpipes.
- Weight: 700g
- Material: Aluminium Fins / Copper Base
ORDER NOW
Acer V243HLbmd 24" Widescreen LED Monitor (ET.FV3HE.L07) @ £152.99 inc VAT
The V243H is large 24" Widescreen 16:9 format display which brings to the home a perfect balance between best value performance with full high definition technology supporting the latest requirements for digital home media and cinematic applications. Thanks to the 16:9 format cut you can view your photos or movies over a broader cinematic area for a thrilling experience. The V243H full high definition display supports the latest Blu-ray devices for FHD/HD true digital content with a dramatic visual impact for entertainment and multitasking. The V243H is a brilliant display reproducing crisp data and media over a cinematic format with the added benefits of a higher resolution performance. In addition, the aesthetically pleasing design portrays a contemporary style that easily compliments any home or work environment.
- LED Backlit
- Screen Size: 24" Widescreen
- Resolution: 1920x1080
- Contrast Ratio: 8000000:1
- Brightness: 250cd/m²
- Response Time: 5ms
- Viewing Angles (H/V): 170°/160°
- Colours: 16.7 Million
- Inputs: 1x Analogue & 1x DVI-D
- VESA Compliant
- Dimensions: 567.0mm x 402.7mm x 200.0mm
- Weight: 5.3kg
- Warranty: 3 Years
Only £152.99 inc VAT.
ORDER NOW
- 2MB L2 cache
- 6MB L3 cache
- DDR3-1333 support
ORDER NOW
- 7 expansion slots
- 2 x USB 2.0
ORDER NOW
ORDER NOW
- 1600MHz
- XMS Heat Spreader
ORDER NOW
- Lifetime Warranty
ORDER NOW
ORDER NOW
- 2x USB 3.0
- 10x USB 2.0
- 3x IEEE 1394a
- 1x PS/2 Keyboard
- 1x PS/2 Mouse
ORDER NOW
- Core Size: 32nm
- Socket: LGA1366
- Six Core
- Multiplier: 25x
- L3 Cache: 12MB
- QPI: 6.4 GT/s
- TDP: 130W
ORDER NOW
- 2000MHz DDR3
- Lifetime Warranty
- 1.65 Volts
- 240 Pin DIMM
ORDER NOW
- 1600MHz DDR3
- CL 8-8-8-24
- Unbuffered
- Lifetime Warranty
- 1.65 Volts
- 240 Pin DIMM
ORDER NOW
- 1 x 4-pin CPU
- 1 x PCI-E 6+2 pin
- 1 x 4-pin floppy
- 2 x S-ATA
- High efficiency
- Active PFC
ORDER NOW
- Capacity: 50GB
- Warranty: 3 Years
ORDER NOW
- SLI Ready
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- Warranty: 2 Years
ORDER NOW
- HDCP Capable
- ATI Avivo HD
- Warranty: 2 Years
ORDER NOW
- HDCP Capable
- ATI Avivo HD
- Warranty: 2 Years
ORDER NOW
- HDCP Capable
- ATI Avivo HD
- Warranty: 2 Years
ORDER NOW
Write Speed
- DVD-R: 24x
- DVD+R: 24x
- DVD-R DL: 12x
- DVD+R DL: 12x
- DVD+RW: 8x
- DVD-RW: 6x
- CD-R: 48x
- CD-RW: 32x
Read Speed
- DVD-R: 16x
- DVD+R: 16x
- CD-R: 40x
ORDER NOW
- Capacity: 1TB
- Cache: 64MB
- Warranty: 5 Years
ORDER NOW
- HDCP Capable
- ATI Avivo HD
- Warranty: 2 Years
ORDER NOW
- Weight: 700g
ORDER NOW
- LED Backlit
- VESA Compliant
- Weight: 5.3kg
- Warranty: 3 Years
ORDER NOW
