- 29 Sep 2003
- Newcastle upon Tyne
By the sounds of it you saw the ipad and wanted to justify it anyway you could? Fair enough, but just admit thats what you wanted in the first place!
I just checked the res of the ipad screen: 1024X768, 4:3 bit backwards isn't it?
Actually I didn't! I derided the iPad from the word go! However, after getting a new laptop (13" MBP) I realised that what I wanted was something more comfortable to use, and I felt the MBP just isn't worth £905 (it's being collected by TNT today to go back to Apple for a refund). I had a hard think about it and it then seemed apparent that the iPad might actually be the best tool for the job!
Re. The screen, because you can use it either way, means you can have both a 1024 or 768 vertical resolution, which is much higher than a netbook since you can't use them sideways. Less vertical scrolling, yay!
