Swan Necks?
9 Aug 2004
Milton Keynes
After a swan neck spanner (22mm) but dont want to spend ~£30 on a whole set an ideas where can buy 1 size or anywhere sells cheaper sets? Cheers steve!
Goto a local tool shop, old style type of place. It is was I did and the guy let me try a few different ones to get the best fit before buying the one I wanted. I am guessing it might be for your suspension top mounts?
Yep, well other halfs car mine just a normal spanner :(
