- 22 Aug 2009
- Nottingham
Am thinking of instead of having all the rads rez pumps in the case i would go for a all in one unit. are these any good.
would look for an AC (read connects to the mains) pump IMO, easier to test because you don't need to unplug everything or use another PSU.
for the CPU block it might be worth going for an EK supreme HF
Got to say this is a good call. As someone who started out with an Eheim 1250, a heatercore and an original WhiteWater, I'd forgotten some of the benefits of AC pumps until I did an old-school build out of the old parts and being able to turn on the pump with no risk to the PC is great. For testing, it really does de-risk the testing process.
Surely by the same merit you also run the risk of turning on the PC and forgetting to turn on the pump?
wouldn't be a problem if you use a UPS, and if the temps get too high the PC shuts down anyway
