Titan Fenrir or Xigmatek Dark Knight?
18 Feb 2010
Liverpool
As above really, I'm looking for a cooler for a new build.
Going to be AM3 - Phenom 955. So which of the two would be the best, should point out that i will be using the standard fans of each of them, TIM will be AS5 probably.
Of course if there is a better option for £30 or less then I would be glad to hear it.
Thanks in advance.
Stock fan on the Titan is quite loud on full pelt, don't know about the other one. I fitted a Titan for a friend then added a Redwing fan. Great cooler
fenrir, I'm using it on my athlon 620,
using occt 4x100% load @ 3.6 ghz 2.6 nb at 1.45v vcore,
max temp is 48c.
Little annoying to fit, but once fitted does the job fine.
I am using the Dark Knight overclocked to 3.77Ghz on this chip. Idle temps are at 29 degrees, loads at 53 degrees. It runs very quietly in comparison to the Titan and is better looking.
