16 May 2010 at 12:13 #21 chipps101 chipps101 Soldato Joined 8 Jan 2010 Posts 4,071 Location Dundee the intel retail boxed ssd's come with a 3.5 bay adaptor so you wouldn't need one of those if you decided to get an ssd.
16 May 2010 at 12:41 #22 CAT-THE-FIFTH CAT-THE-FIFTH Caporegime Joined 9 Nov 2009 Posts 25,768 Location Planet Earth There is the non-USB3 version of the motherboard for £108: http://www.overclockers.co.uk/showproduct.php?prodid=MB-392-AS
16 May 2010 at 22:21 #23 Fel Fel Associate OP Joined 6 Apr 2010 Posts 73 Location UK CAT-THE-FIFTH said: There is the non-USB3 version of the motherboard for £108: http://www.overclockers.co.uk/showproduct.php?prodid=MB-392-AS Click to expand... I think £11.00 is cheap enough for USB 3.0 support without having to buy a separate card in the future. Going to ponder the AMD/Intel decision for a few more days - maybe see what ocuk come up with on Weds. Then the final decision whether i can be bothered to build and overclock myself or buy o/c package.
16 May 2010 at 22:24 #24 stulid stulid Caporegime Joined 17 Jan 2010 Posts 66,731 Location weston-super-mare Fel said: I think £11.00 is cheap enough for USB 3.0 support without having to buy a separate card in the future. Click to expand... Absolutely! why compromise
16 May 2010 at 22:30 #25 Fel Fel Associate OP Joined 6 Apr 2010 Posts 73 Location UK I have to draw the line somewhere though - another £40 buys me the Crosshair IV .... ... and that leads back to the original proposal - the Ultima Raptor
