Mounting Screws for H50-1
29 May 2009
Plymouth, United Kingdom
Where can I get additional mounting screws for the Corsair H50-1? I want to run it in a push-pull config :D
I found the specs by Googling - there's a link somewhere on the first page of hits to a Corsair blog post about it. Then I discovered I couldn't find a source of the screws. I'm off to my local hardware emporium when it's open after the weekend.
As a quick fix, someone suggested using two screws to mount the push fan and two to mount the pull until you source more screws. This works well for me as a temporary measure, and seems to hold both fans fine without vibration.
EDIT: Corsair blog post here.
Although it is always nice to get hold of additional screws, surely you can mount the fans by using 2 screws each on opposite corners. At least temporarily.
- Ordokai
I will do that temporary, but would really like to be able to have all 4 in each just for peace of mind more than anything.
Hi mate
Go to a well known auction site and look for
6 x 32 x 1 1/4" unc stainless allen head cap bolts
£4.95 gets you 10 and they fit perfect
hope this helps
Confirm that 6 x 32 unc are the size you require and 1 1/4" are the longest that you should use to prevent radiator damage. :)
Could be really cheeky and raise a RMA with Corsair saying that the mounting screws are AWOL and they will send you a replacement set? :)
Hey Ryan,
I managed to find some of the H50 screws whilst I was in Singapore and I have some spares.
If you send me your address I'll send you a set of the screws...no charge of course :)
diverse.
