Does OcUk save its settings somewhere, ??
How Do i revert back to the ocuk profile?
Thanks
It looks like they've got these bundles coming off a production line now and aren't putting in due care and attention, you'd probably need water to keep it cool at those settings.
They just get it to whatever advertised speed in the easiest and fastest way and not the most efficient. Never buying another overclocked bundle from them again. Expert overclockers maybe, bit careless though.
It should be either F11/F12 in the BIOS, one of them loads profiles and the other saves.
This is what I am beginning to suspect unfortunatelyThey just get it to whatever advertised speed in the easiest and fastest way and not the most efficient. Never buying another overclocked bundle from them again. Expert overclockers maybe, bit careless though.
fluidz, sorry to hear of your overclock bundle problem, the best way is to email ocuk support and or you can phone up support to get this sorted out. I would take it back and let ocuk staff have a look for you. You had 12 months under warranty with them. Good luck mate and I really do hope that your overclock bundle will be more stable and better temperature pretty soon. I just notice your screen, your north bridge temperature is pretty bad indeed at 67C !!!! As mine is just 38C when overclocked 4.4Ghz!
Dont CPU's shut down or at least slow themselves way down when they start to thermal throttle at like 100C? So maybe it is faulty sensors?
I am merely speculating ofc.
can't see it being faulty sensors as they are individual sensors on there.
Did you try setting QPI/VTT manually yet like I suggested earlier? leaving voltages on auto is generally bad.
Those readings in the BIOS just show stock un-overclocked values, it sounds to me like you got a bit of a bad chip and OCUK just pumped silly volts through it without any regard to temperature.
