I'm having a major computing crisis: I've lost pretty much the entire contents of my 'user' folder (pictures, documents, music, itunes library, downloads, etc.).
I'm using Windows 7, and I've been using this combination of hardware to store my windows User profile (only the folders, ie. Documents, and not the actual User folder):
The current problem however is unrelated to iTunes. On Friday I had my 2.5" drive plugged into my work PC (via eSata cable), but the drive wasn't in use. I also needed to perform a manual backup of my work system onto ANOTHER external 3.5" drive, so I plugged it in via USB cable. The transfer was about 150gb, so I thought I'd try eSata since the 3.5" enclosure also had eSata port. Since Windows doesn't have any 'eject' function for eSata drives, and it wasn't being used, I just pulled the plug out of my 2.5" drive, and plugged it straight into the 3.5" drive (which was empty bar 1 folder).
I rescanned for new devices (Device manager) and the new drive popped up, so I restarted transferring my work-pc backup onto the 3.5" external drive, now via eSata so much quicker. Sooner or later the transfer was complete, so I switched the drives back over and now had my 2.5" drive back in via eSata. I rescanned for new hardware, my drive popped up but oddly it still had the label of my 3.5" drive "CR External". It also showed it was only using 20-30gb out of 600gb, whereas I KNOW previously it only had 200gb FREE
I browsed into my 2.5" drive and for some reason all of my personal files had disappeared bar 2 folders - "My Videos", which contained 50-70 of unimportant clips *not prawn
*, and "Backup" which contained about 500mb of my WORK-PC backup files that should have been transferred over to the OTHER 3.5" drive o_O
I think what has happened is stupid Windoze hasn't realised the drive swap even dispite manual device rescan, and has obviously delayed a portion of my WORK-PC backup transfer and stupidly placed those files onto my 2.5", and in the process deleted the files which should have been on my 2.5" >_<
Question now is - how can I retrieve these files?? I havn't performed any/many write actions on the 2.5" since - should I use a drive recovery software, and if so - where do I begin??
Any advice would be much appreciated, as I'm trying get back pretty much 10-12 years of valuable documents, files and music
 I know it was stupid to keep important stuff on an external but I didn't think an operating system could be this querky.
Thanks.
- 640gb 2.5" 5400rpm SATA hard drive
 - http://www.overclockers.co.uk/showproduct.php?prodid=HD-033-BT
*, and "Backup" which contained about 500mb of my WORK-PC backup files that should have been transferred over to the OTHER 3.5" drive o_OI think what has happened is stupid Windoze hasn't realised the drive swap even dispite manual device rescan, and has obviously delayed a portion of my WORK-PC backup transfer and stupidly placed those files onto my 2.5", and in the process deleted the files which should have been on my 2.5" >_<
 I know it was stupid to keep important stuff on an external but I didn't think an operating system could be this querky.Thanks.
 After 10-12 years of not having lost any files (bar half of my MP3 collection accidently deleted a year ago -.-), I got pretty confident nothing would happen, especially with a 100 x advanced operating system and hardware. I did have a tingly sensation that something like this would happen though, maybe it's a sign that I need to wipe my hard drives, sell my parts and get out of my damn room!
