My NB temp monitor is broken and the temperature stays fixed at 29-31 degrees and never changes. I've tried with both Asus Probe and HWmonitor.
Unless I were meant to install something to make it work ...
Even in the BIOS?
Even in the BIOS?
.I just checked and yes, the MB temperature is fixed to 31 degrees in the bios as well, and this is the value that it never changes from in any temp monitor in windows.
Bios problem, or faulty hardware? I hope its not faulty.
.1. When did the problem first occur? Did it occur after installing a new peice of hardware, i.e the RE3 (or did you buy it all at the same time)?
2. Do you have any backup/spares in the hardware department, i.e. a spare graphics card/PSU/RAM etc?
This board looks more like a lemon every day that passes, another 2 people found that the cpu socket was missing srews and almost hanging off, then there people with missing NB screws or really bad temps...think im going to cancel mine im not paying £300+ for something that can hardly match a UD5 and made worse then a tonka truck
Buy a new car and the wheel falls off you be ok with that would you? I think a cpu socket barley attached to the mobo is a bit more the ops a screw missing. You are on the other right i dont need to upgrade from a UD5 nor did i need to do any upgrades that i have for the past 5 years that is not the point. you pay top doller mistakes happen but not when there that many poping up day by day
The problems with the video card seem gone. I've plugged the GTX 480 into the next PCIe slot. I dont understand why this would suddenly work but now I'm a happy camper![]()
.snip
but glad you understand the point of the analogy as it had nothing to do with money its called "fit for purpose" Any ho maybe i can add something posative when it arrives may be a while for stock anyway so will wait and see.
I had great hopes for this mobo until the reviews came in, it does look nice though..
Mine gets delivered tomorow do hope it comes intact..
and not with screws missing.![]()
I seriously wouldn't worry about it, the only people I have seen complain about having no screws also commented that it was held in place my rivets... spot the obvious face palm?
