- 17 Mar 2004
I find it odd considering Japanese attention to detail something so primitive was overlooked at the factory.
Getting the bolts checked is actually a really straightforward job, if they are not corroded you can pay a specialist an hour or 2 labour to get them out, grease them then pay for a geoemtry.
It's only once they are corroded and stuck the £££ racks up.
This is the last time I will say it.
There are no UK AP2 cars. They are all AP1 which have the AP2 styling changes.
When you are next at work go and read the engine code, F20C right? 2.0 Litre.
your so wrong, the chassis codes we write down from the windscreen sticker or vin plate or at the bottom/left of the windscreen are all AP2! we don't have any AP1 onsite as they are too old, and can't be resold, they would only be good for auction.
engine code is F22C thankyou very much.
Why is every single S2000 on autotrader registered as a 2.0 then?
You searched everysingle one!![]()
The F20C's bore is 87 mm (3.4 in) and stroke is 84 mm (3.3 in).
Applications:
1999-2004 Honda S2000 (Japan)
2000-2003 Honda S2000 (F20C1) (North America)
1999–present Honda S2000 (United Kingdom, Europe, Australia)
Straight from Wiki
and is it an issue on all S2000's?
Honda didn't realise their mistake and sort it out on later cars?
Try the Honda Website, they have a degree of motivation to keep their site updated and current, unlike Wiki.
Unfortunately I would have to disagree with Sin Chases opinion on handling.
You mean like Honda Happiness warranty which is JUST like a Honda warranty and not from a 3rd party...oh wait....it's from a 3rd party and NOTHING like a Honda Warranty.
Considering the S2000 is now out of production how would the Honda UK website be of any use anyway?
A cookie to the first person who can tell me why the S800 was called the S800.
