- 4 Jun 2009
- Solihull/Cardiff
As the title basically, I've been asked to help a friend build a new PC, with a budget of £470 absolute maximum. I've heard good things about the i3 rig below, I'm wondering what you experts think?
It won't be used for gaming, and will run on integrated gfx for now, possibly adding a 5770 later if he changes his mind on the gaming front. I will probably push it as far as possible on stock voltages then take it down a notch or two, so a good cooler will be needed, I'll be aiming for 3.8GHz +
I just need the tower, no keyboard, mouse, monitor or OS etc
Thoughts on this spec?
As far as I can see its only missing a CPU cooler (OEM i3's don't come with a stock cooler do they? I was under the impression that was the difference between the retail and OEM)
So I'm looking for a CPU cooler for this rig, £35 to play with for it, which counts out an H50
I must admit to knowing very little on the AMD side
Poor form I know, but I've heard good things about the 8x0 motherboards, but they seem more expensive the H55 above, could someone suggest a similar priced AMD system and give me the pro's and con's of each
I know you guys will do me proud once more
Cheers in advance,
Matt
Poor form I know, but I've heard good things about the 8x0 motherboards, but they seem more expensive the H55 above, could someone suggest a similar priced AMD system and give me the pro's and con's of eachI know you guys will do me proud once more
Cheers in advance,
Matt
I bet it does wonders for the cooling not having one though....
