I'm on the laptop right now, there's no task bar, there's no cmd propt, I can't do much at all, the only reason I can get into the C drive is because I can access it via internet explorer. I loaded up safe mode with cmd propt and it booted me back out saying I have to activate windows and to log back in to normal mode.
Unless there is a way I can launch cmd propt via internet explorer by typing in the short cut
Have you tried manually starting explorer.exe from task manager? (Shift+Ctrl+Esc or Ctrl+Alt+Del)
And as Azza said, once you get the explorer up, just backup and reinstall.
Just copy her stuff onto your PC / external hard drive and then format and install Vista using her key? Or your cd-key.
Not exactly a hard job.
But if they re-install with the CD-key they have now, won't it just be deactivated?
If it's the key on the COA (sticker on bottom of laptop), then it's completely legit.
This time, just make sure they get it activated online or over the phone well before the trial period expires.
I've never heard of the task bar disappearing before.
Just activate it online as soon as you have re-installed windows, saves having to show her how to do it.![]()
Yeah but she wants all her pictures etc, so formatting isn't so much of an option at the moment.
Running CMD as admin still comes up with the same error:
C:\\Windows\system32\slmgr.vbs
Line: 1648
Char: 9
Error: 0xC004E017
Either go to the microsoft website and buy a new copy, input a new CD-key OR ask dell for help.
Use a Linux live cd like Mint or Ubuntu to get access to the drive and recover the files, it's ridiculously easy to do![]()
Aye, the whole thing was blank, with 3 options:
There was no activation option, but when I went on the website it did ask if I wanted to activate it, I pressed yes and then it came up with the thing which says "Right click computer > Properties > Activate windows" But it was so locked-down, you couldn't get into the properties, so it was basically useless.
Sysprep would have worked, have had to do it myself before.
Silly question, but did you try putting the key from the COA in the New CD Key box and activating?
Tried sysprep, did nothing
