Caporegime
- 18 Oct 2002
You missed the point of what I was saying... even if they make an absolutely superb piece of hardware - and being intel I'm pretty sure the will in the end - they absolutely won't make it in the gaming GPU market... intel simply lack the mentality to make it work and no amount of R&D, money or time will fix that. They should stick to what they are good at like CPUs.
You said Larabee is dead, thats 100% inaccurate, I also didn't miss what you said.
You keep saying they don't have the mentality, and thats just the daftest thing I've ever heard. They have the money to kill the current Larabee, buy the entire developement team off Nvidia and have them build them a AMD/IBM/PS3/Arm style core, whatever they want, if they want.
You've decided that Larabee isn't what YOU think it should be and are having a go at Intel.
In all likelyhood Intel will end up incredibly competitive in high end gaming within 3-4 years but their first goal as a intergrated GPU thats absolutely 100% usable as extra FPU processing power as standard for ANY app that wants it.
THey have exactly the right mentality about it because their FIRST move is to make an on die gpu that can be FULLY utilised as part of the CPU first and foremost, their current design will be incredibly optimised for just that purpose, making a larger derivitive with more cores and more functionality is simply the next step and I have literally no doubt Intel can do it, because at worst, they can afford to through out a several billion pound project, start again or make secondary performance GPU project as and when they like.
Larabee, as it is intended to be, is much closer to a x86 core, offering easier programming and more gpgpu like structure, that is the exact way Nvidia is going, just on a much more optimised platform with literally decades of experience, it was never going to happen overnight. The only mistake Intel made with Larabee is giving the impression it might happen overnight to people who really don't get its going to take years.
Current gpu's are moving towards a gpu-gpgpu-cpu cross, and Larabee is just moving into the middle from the otherside, it will still end up in the same place.
AMD/Nvidia will be pushing for better compability with general processing usage, being natively c+ programable, being more accessible for normal computing, and Intel are simply and understandably starting from the other end, and moving the other way, to add more acceleration and graphics appropriate hardware into it.
You seem to miss that Intel has FAR more experience with normal software and has a huge advantage in terms of being able to converge its own cpu/gpu plans together as IT see's fit, in a way Nvidia simply can't and also move and design a plan that will end up with their cpu/gpu encased in the same package and eventually in a way that programs can be compiled as normal but take advantage of the on die gpu.
Nvidia will literally NEVER have that level of intergration and will never be able to compete large scale on GPGPU in the future.
Why, because in 4 years at 16-32 cores there will be multiple types, a octo cpu with 24 gpu cores that can be seemlessly coded to use all the power easily.
EDIT:- Its also worth noting Nvidia being bought by anyone is incredibly unlikely, they aren't making good mobile products, with all their design wins for Tegra(most of them) actually ending up in production with other cores as they miss targeted specs constantly, its a fair point, how many Tegra 1 design wins were there, and how many products, loads of "design wins" smeg all products. Their GPU line is, well, on course for a catastrophic failure without a massive rethink, their CEO is pushing the desing for one goal and its contrary to the manufacturing industry, for 3 years production has been getting worse with no sign of a change from Nvidia.
They are an idea's company, nothing more or less anymore, if their idea's fail to the tune that they'd be worth buying in terms of price, the value of the company without a decent gpu design, will have simply evapourated. The only value they'd have is some very good engineers, who can simply be lured away with jobs and cash. The entire value of the company is its design team, you don't need to buy the company, just hire the team. If they made their own gpu's and couple provide an entire supply of a new design and had the process tech to go with it, they'd be worth billions, they aren't.
