- 18 May 2010
Hi
I know this is a new board but I was wondering if anyone had any info on it, information around the internet is scarce.
Here is the board, I am waiting for it to be released it should be appearing this week hopefully
Edit : http://www.gigabyte.com.tw/Products/Motherboard/Products_Overview.aspx?ProductID=3423
Basically I dont want to overclock I want to run a standard system but a decent one.
What I really want to know is if this board will support 6 core straight out of the box, i've noticed a lot of information that I have found state a different revision for this board, mostly Rev 2.0 which is strange
Also, I only want to run a single GPU probably a 5870, I imagine this board will run a single GPU as well as any of the top end 890 FX boards will run a single GPU, I am not bothered about Crossfire.
As I dont want to overclock am I limited to DDR3 1333 memory that will be the quickest plug and play memory? Or is there a way I can get quicker memory in there as i've noticed there is quicker memory available
Thanks for any help
Thanks for any help
