ANTEC P183 PERFORMANCE CASE - ONLY £95.99 INC VAT.
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
The Antec P183 is now down to £95.99 inc. VAT. You would be mad to miss out on this great new low price.
Antec P183 Super Midi Tower Case - Gun Metal Black @ £95.99 inc VAT
Building from a proven design, Antec introduces the P183, the next chapter in our Performance One Series enclosures. Dual chambers isolate the power supply and CPU into separate cooling zones, with up to five configurable fans for unsurpassed cooling. Three-layer, sound-deadening panels dampen noise even in the most demanding systems, ensuring quiet operation. The original P180 was a breakthrough in case design, and now the P183 carries on the tradition, ushering in the latest standards for cooling and quiet.
- 11 Drive Bays
- External 4 x 5.25”; 1 x 3.5”
- Internal 6 x 3.5” for HDD
- 7 Expansion Slots
- PS/2 size power supply or the unique Antec CP-850
- Cooling System:
- 1 rear (standard) 120mm x 25mm TriCool Fan
- 1 top (standard) 120mm x 25mm TriCool fan
- 1 lower chamber (optional) 120mm x 25mm
- 1 front (optional) 120mm fan
- 1 middle (optional) 120mm fan
- Divided upper and lower chamber structure: the power supply resides in a separate chamber with dedicated cooling from a 120mm fan to isolate heat from the system and lower system noise
- Innovative three-layer side panel and front door (aluminium, plastic, aluminium) dampens system generated noise, making this one of the quietest cases available
- Double-hinged door designed to open up to 270º for easier system integration
- 0.8mm cold rolled steel throughout the majority of the chassis to enhance durability
Only £95.99 inc VAT.
ORDER NOW
The noise dampening qualities on this case are second to none. Having owned one myself they are so quiet.
I did upgrade to a Corsair 800D though. But for the price it's a great item.
Yes our stock is V2. The CPU cutout is the cut out on the motherboard tray to allow you to change the CPU cooler backplate without having to remove the motherboard from the case.
