Your skin care routine?
Shower in the morning and after sport using whatever shower gel is going cheap at the time. Maybe once or twice a month if my skin feels dry I might use a bit of e45 or whatever I can find. Never had a problem with my skin, eat a better diet now and drink lots of water.
A splash of paraffin each morning, and a quick scrub with some wire wool to exfoliate before bedtime. The ladies love it.
Clean and clear in the morning with a bit of moisturiser and just use a damp flannel at night.
I don't give a **** if it's "gay", there's nothing cool about not getting fanny :D
+1
like most real men :D
Appreciate that does nothing for some people.
Spots and dry skin are nothing to be proud of!
Those that don't believe it. When your missus isn't looking, after you had your shower and wash your face with your normal routine, basically when you stop. Go get a cotton rounds and put on some cleanser and then wipe on your face. Then look how much crap that wipes off. Face wash doesn't wash away everything.
Been reading around these forums and found lots of 'gay' man threads! (I'm not gay btw :) )
Decided I'd subscribe and ask!
What's your skin care routine?
Personally I have pretty poor skin so treat any blemishes at night with Benzoyl peroxide and wash with a gentle cleanser!
You? :p
Soap, water and a Towel....simples!
I wash my face in the shower with some Simple face stuff, when I wash it apart from that I just use water. I only moisturise my face when it wants it.
It actually appears that I've finally pretty much grown out of spots aged TWENTY FIVE, which was a relief. Still get them sometimes but nowhere near like I used to.
I get really dry hands sometimes so I use MANLY NORWEGIAN HAND CREAM FOR FISHERMEN. Or girl's stuff from Wilko. They're the same pretty much I think.
If I wash my face with normal soap, about ten minutes after it starts to screw up and feels like it looks like a cat's ********.
I should have got into the cosmetics business, there are so many mugs that buy this crap I could have made a fortune! :D
Bring back the Neanderthal men! This sort of behaviour is being accepted now as being normal! It's just not right! :mad:
