ASUS add 4-Way SLI support to Rampage III Extreme
30 Jul 2005
Bristol
with an expansion card running NF200 chips !!!! :eek:
full info over at tweaktown
http://www.tweaktown.com/news/15345/asus_add_4_way_sli_support_to_rampage_iii_extreme/index.html
Surely the GFX cards wouldnt fit the case properly as the slots are raised from where they should be.
Looks horrible as well to me
4 x 480gtx + Radiator = New Boiler for house? :D
Also, what if your case doesn't have space for the overhang at the bottom?
Dont quote me, but I really don't think it's designed for use in a case - Anyone who can run 4 x GTX480 in a case get's a salute from me though.
My thoughts is this is for those crazy people who want LN2 world records. Interestingly, from the figures I've seen the add-in card gives performance increases of ~2% over the UD9's onboard solution.
crazy design, it would be better for them to make a new motherboard and put include the daughter board than put that on top, also what happened to the other component underneath???
not a good design i believe the designer was drunk, or high
Actually I think it's a good idea. Unlike the Gigabyte UD9 which is an XL-ATX board, the Rampage III Extreme will fit into most cases so it's easily accessible to the public. The only people going for a quad sli setup using gtx480s/470s will most likely have it outside a case anyway so the daughterboard can be used in the situation.
So by having two separate boards, ASUS are catering for both general users and the hard core enthusiast as VK said. Gigabyte on the other hand have already alienated most users with their form factor. Sure with the daughterboard, you won't have a PCI slot for sound cards or whatever but that's not necessary when you're trying to beat records with 4 cards.
Not only that but the UD9 is set to cost around 500 quid, which is a fair bit more than the RE3. By having the NF200 chipset on a seperate board they can lower the price of the RE3 itself, compared to the UD9 which has everything packed onto one board.
So basically, it's designed to give Quad-SLI on R3E - For this you need 2 x NF200 chips, due to the Nvidia design. - Xpander adds 2 x NF200 and 4 x PCIe x16 slots to give you this.
Xpander will be installed on the 1st and 3rd slots of the board.
The reason for this design, in my opinion, is that the NF200 chip can actually decreases graphics performance by approx 1.5% - Something you can't really allow on a board designed for breaking world records.
In the case of NF200, X16+x16+x16 is SLOWER than X16+x8+x8
(HardOCP did some research on this, if you're interested) http://hardocp.com/article.html?art=MTYwNiwsLGhlbnRodXNpYXN0
So in the case of the board, the R3E outperforms a certain competitors board by approx 2% with 4 way CrossfireX 5870s. (Showing that if the design is right....Quad x8 > Quad x16)
When we look at Quad SLI figures themselves, the performance difference is approx 1.2% with 4 x GTX 480 (R3E with Xpander vs other)
In my opinion, the reason for the Xpander, instead of an onboard solution is quite self explanatory....
4-Way SLI is not for everyone, in fact, less than 1% of users use it.....NF200's are expensive, hot and are 6w of power each....If you dont *need* Quad SLI, they're just a bad addition for you, in terms of additional cost to the board. - Basically, you decide how your money is spent - Not the motherboard manufacturer.
(Note, you'd need 2 x PSU to run 4 x GTX 480 in Quad SLI anyway....) So when it comes down to the target audience of the board....you have the option of adding Xpander, if you really must have Quad SLI. It'll be a struggle to fit in a chassis, that's a fact...but anyone who is running 4 x GTX 480's isn't going to be doing so in a case.....unless it's a custom build (Can you imagine the heat of 4 x GTX 480 + 2 x PSUs!??!)
Where is my sample, that's the question! Early indications say that this will be coming available in July - So I'll probably have one in June.
Now to find 4 x GTX 480s...
I highly doubt this is designed to be used in a case, even EVGA's Quad-SLI motherboard isn't standard ATX size.
And anyway, Nvidia's Quad-SLI drivers only work in 3D Mark Vantage (I believe, after reading a review over at Guru 3d on 4 Way-SLI), so its soley for benchmarking
How-ever, it does look a bit like a quick fix / bodge rather a proper effort and making the motherboard
