Cosmos S or Storm Sniper
15 Apr 2009
I'm having a hard time decided between the two cases, any opinions/suggestions?
Aesthetics isn't an issue as I rather like the look of both of them, i've just heard that
a) the Cosmos S doesn't have the greatest cooling
and
b) the Sniper has somewhat weak/dodgy expansion clips
are either of these issues a real problem or are they just small niggles?
Thanks for your advice and help :)
Hi
You can remove the clips on the sniper and use the provided thumb screws to secure the expansion cards.
But if you want good cooling i would spend an extra £10 and get the lancool k62 :D
I used a sniper on a friends build and the inside of the case is very small and not very good cooling.
and
...widen your choice ? oh and welcome to the forums :)
