- 19 Dec 2006
- Saudi Arabia né Donegal
Probably the above
However, for future reference when rounding to the nearest range you look at the number just to the right of the order you're rounding to, if that number is between 1 and 5 then you round down and if the number is 5 or greater then round up.
From your example if we were to round to the nearest ten then we would get £1320 as £20 is the next nearest ten since the number to the right of the 10 value is 6.
If we were to round to the nearest 100 then it would be £1300 as £100 is the nearest 100 since the number to the right is 1.
The question as you phrase it makes no sense so it's either wrong or a trick.
