the Lock speaketh the truth
i have a 5870 at the moment but wish i had never got rid of my 280 SLI
easily the best graphics configuration i have ever had.
Tell me that now why dont you
hahaThen again, isnt the 295 just 2x280s? on one card?
hahaCorsair HX620W PSU < Is that enough?
I did a quick search and it seemed to confirm my first thought - you will be fine
Does your version of the HX 620W come with a 8 pin PCIe cables as well as 6 pin ones? If not, have a look here and you can request one (as the GTX 295 needs an 8 pin as well as a 6 pin PCIe power connection).
Pretty much, its got a bit less memory per core, a slightly narrower memory bus and marginally marginally lower clockspeeds. However, its core are built on the smaller, newer and cooler 55nm manufacturing process. In terms of performance the GTX 295 sits between a GTX 260 (216 core) SLI and a GTX 275 SLI arrangement.
