Zotac ZBOX Ion2 Mini PC - Hard Drive question. & few other questions on things.
15 Nov 2008
Scotland / Blairgowrie
Looking at a review of this pc and really the insides of the pc look so compact i dont think there can be any sory of internal HD fitted. I am looking to buy this for my dad, i would have to spend £200 on my old pc to fix it up but id rather buy this. Could anyone show me some decent websites what show where you can put a HD inside this? theres only 1 review on youtube and it aint very great.
Also. Is it possible to get a USB splitter. My plan is to have the pc mentioned above. Have the same keyboard and mouse, plugged into some sort of device what makes the keyboard and mouse avaliable on each pc without having to disconnect and connect.
And is there the same sort of device what can share 2 pcs with 1 monitor. ( plug 1 dvi in a thing then it produces 2 dvi links to connect to 2 different pcs. )
Sorry if all this sounds crazy, iv looked on google but cant find anything. Knowing me i dont look hard enough but this time i have.
I want my current pc just for games, im sick fed up of my dad and all his pictures/videos etc filling up my HD. So im hoping to get that Zotac ZBOX, stick a 250gb HD in it and let him use that, ill probably use it as well when im not gaming.Yes i have an external HD what can get used but that is for backups. For his use not mine.
Any help/info would be appreciated.
I only have 1 sata port left and thats probably going to come in handy sooner or later so no more Hds in my pc. Iv got all 3TB used up.
You need a KVM switch (USB version).
From a quick Google..
Space for a 2.5-inch hard drive and 200-pin DDR2-800 SO-DIMM slot enables users to customize the internals of the ZOTAC ZBOX HD-ID11 to their own needs
So you should be able to take any of the standard 2.5" HDDs that OC sell
