Cheapest way to move a car?
9 Aug 2004
Milton Keynes
This is our about our second car..
Have an old clio which wasnt worth putting through an MOT due to rust/suspension/brakes needed doing (roughly £400 of stuff and body work sucks). Now been given another clio which has sat still for 2yrs, obv no mot or tax. It runs okay actually (body work is really good) after a new battery however will need new pads/dics and a new/replacement rad, a service and 2 front tyres.
So was thinking of making a good one out of the two using the old one for spares (rad) and tyres (2 new ones about 2 months before stopped using it) and getting new brakes, plugs, oil, etc (roughly £100) however how do i get it home?
If i got day insurance would that allow me to drive it to an MOT which it will fail and then drive back to the new home allowing me a week to repair before getting MOT'd or as no tax would I not be able to do this?
Alternatively would I be able to tow it with another car or does it still need its own insurance?
Sorry if bit confusing!
If you are just scrapping the remains of the left over car some scrapyards will collect it from you depending on its worth. Might be worth a punt
I personally would use (scam) the AA into doing it for me, make the scene look like a breakdown and get it relayed home.
Will do that with the old one however we have old one here and new one 12~ miles away which is one needing to be moved now!
Will try Rac as have any car personal cover i think! What would i say the fault is though??
Worth a shot, i guess you will need to disable the new car in order to make it look like a breakdown.
You are the one who has the mechanical knowledge to combine 2 cars into one working one though, you decide how to actually create the scene :p I'd suggest you would need to put a working battery in it so that it at least looks like it was being driven as a starting point.
Yeah just wondering what they would be willing to tow ie need to work out what they cant sort out on side of road and would be willing to take home for me rather than fixing.. hmm
Surely as a customer you can insist that you do not want it fixed there and then, and want it towed home so that <your specialist mechanic may look at it>/<insert reason>?
All you have to say is the brake pedal went to the floor and you no longer have any faith in the brakes.
Job done, they have to recover you.
I did something like this not so long back. I Went to buy a non runner which was located behind a garage that had taken a look at it and diagnosed it with no compression. I was buying the car for the good body panels which was the same colour as mine and some other desirable parts to fit on my own car . Because both of the cars were the same car AND colour, i took the number plates off mine (taxed insured and motted), put them on the non runner car (sorned) and called the AA.
They asked a few questions over the phone, i told them the cambelt had snapped and it will require a flatbed and winch. They picked it up no problem and drove me and the car 40miles back using the 'RELAY' service.
I originally called the RAC, and they flat out refused to take it because the car was deemed as 'at a place capable of fixing it'
HTH
